1W bottom end, forged pistons, VAG rebuild parts
Up for sale is a 1w diesel bottom end including:
Crank, block, pistons, rods, oil squirters, flywheel
Custom forged pistons to suit a bore of 77mm and a stroke of 79.1mm, which suits the diesel crank
This creates a 1473cc bottom end
I've got an 8P gearbox as well as the over sized Seat Terra radiator (almost new) that could be inlcluded also.
I have about 85% of the rebuild parts (from VAG) including brand new VAG oil pump and water pump
Overall these parts cost me £1300+ - drop me a PM if you're interested and I can answer any questions you might have.
Will obviously need to be picked up due to the size and weight of the bits, I'm based in Cambridge
Henry
  • Replies 11
  • Views 948
Nice setup there mate. interesting to see what would this produces. :-)
Just to mention, pistons are designed for stock G40 compression ratio
Pistons mounted to Con-rods are the stock 1W pistons, forged pistons are still sat in their box
Some more info about the rebuild parts included.
Rebuild parts:
Conrod nuts 052 105 427 (x8)
Conrod bolts 052 105 425 A (x8)
Crank bolt N 902 928 02
Main crank cap bolts N 102 638 01(x10)
Oil sump
Oil sump bolt and washer N 902 889 01 + N 013 849 2
Oil sump gaskets - 032 103 609 B
20 X Sump bolts N 900 184 01
Oil pump 030 115 105 E
Oil pump bolt N 010 215 27
Oil pump bolt N 905 293 01 (x2)
Washer N 012 226 5 (x2)
Oil pump bolt N 010 239 11 (x2)
Oil pump bolt N 010 287 3
Oil pump bush 030 115 112 B
Water pump + 'O' Ring - 030 121 005LX + 030 121 043 B
Bosch Distributor cap
Beru Rotor arm
Crank end plate 068 103 171 F
Crankshaft Circular seal 068 103 085 E
BBT H.T Leads
2 X oil filters
Oil breather dome - 030 103 129
Oil pump chain
Bosch fuel filter -450 905 264
Timing belt - 030 109 119A
Both crank plate gaskets 026 103 181 B + 030 103 161 C
Throttle body gasket - 030 133 073A
Water pipe gasket - Water pipe gasket N 902 600 01
BRV gasket - 030 133 074
Exhaust manifold gaskets - 030 253 039A (x2)
Exhaust studs N 044 410 4 (x5)
Exhaust manifold nuts N 900 850 01 (x5)
Head gasket - 030 103 383 AH
5 core plugs
Blue temp sender + 2 clips - 025 906 041 A
Flywheel bolts N 902 061 03 (x6)
Thermostat housing o ring 030 121 119
Water pipe nuts N 901 752 03 (x2)
TTT, if you're interested in just the rebuild parts, or just the pistons and crank on their own please drop me a message and we can come to some sort of deal
Would you sell the gearbox seperately? If so how much...would collect.
has the block been over bored yet ?
hi mate has all the parts been marked up so id know where they went originaly?
No work has been down to the engine yet. Overboring is generally priced around £20/£25 per cylinder.
Most of the rebuild parts are still in the bags with the part numbers on, but they all vary enough in size and shape to make it quite easy to know where they go once you get stuck in.
I have an O-ring push fit water pipe with ISV mount for the back of the block for sale if Henry hasn't got one in all his bits :biggrin: The original one is plastic and don't have a mount plate on the top.
how much for the block and crank?
