T CUT Advice needed
Hi Guys
Was wondering if you could give me abit of advice....
I've got a polo 6n , its like a dark blue/purple metalic colour and I've just debadged it recently. Going to remove the rub stripes soon.
theres a few marks and I've brought some T CUT colour fast blue from halfords to cover this up
I'm thinking of using this for the marks and also use this on the whole car?
after reading a few posts not sure if this is the right product, any help on this?
Edited by scan
  • Replies 14
  • Views 3.9k
t-cut is shit mate to be honest, i used it after i debadged my last car, didnt do anythin, i then went and bought some g3 compound cutter, used my elecy buffer with that mate and it makes hell of a lot of difference,
yeah I've read mixed reviews about T CUT. I'm only worried as i dont want the blue t cut to change the shade of my car!
I aint got a electric buffer! :cry:
Can i use any products by hand?
Also this is a really dumb newbie question but ...when i use the product,should i use it on the area needed, or do u think its best to use it on the whole car while I'm at it? :?
Edited by scan
you can work it by hand mate just takes alot longer, you can get a cheap buffer for £25, just work it on the area and abit around mate, it wont change the shade of your car either pal!!
This site scares the living daylights out of me sometimes.
You do not use a buffer with cutting compound (G3,T-cut etc) as you'll eat through half the paint.
Not only that,the experience of people working with non-metallic paint isn't very relevant,as you're not working with paint - as you have metallic,you're working with laquer.
Id never advise using normal T-cut because it contains ammonia and is a nightmare to work with.
But Metallic T-cut (glittery dark red bottle) is a well-kept secret on solid paint,as well as the laquer it's designed to be used on - by hand.
Buffers are for polish,not cutting compounds.
right so i should swap the T cut colour fast for some metallic T cut?
the main reason i ask is that on the back of my car you can see a slight outline on the debadged area(1.4 bit). i've wash and waxed it but cant get rid of these marks. they aint really scratches but more of a light mark. I'm taking off the rub stripes this weekend and suspect there may be similar marks on this.
is this the best product to use to get rid of these marks?
thanks
Edited by scan
I use Farecla G3 cutting compound and G10 to seal it...not cheap stuff to buy though.
I agree! Get yourself a buffer! And G3 will not eat through your paint if you use it with water and a proper compounding head. And once you have used that, swap th compound head with a soft polishin head and use that with G10.. This will bring your car shiny as. And remove any swirls and light scratches!
i got told by bobman off ukpassats that you should never t cut your car without claying it first which takes ages, because if there any dirt and crap in your paint its just rubbing it all into your paint . dont know if its true its just hwat he said, so maybe clay it instaed ???? :?:?:?
^^ True, claying will get better results from polishing and should definately be done before any machine polishing.
i agree with Mikey MK here lads.. all he said is true..
although you "can" use a buffer but you need experiance to get a good result without burning through unless your luky as hell, iv seen several lads leave burn mark and impossable to undo..
although I'm not sure about needing to clay it first..
for example on our old passat, 95 reg, the nearside wing was pure faded and dirty and i just sleped on the tcut with plenty of elbo grease on thes like new, however the roof and bonnet will have alot more of a scum build up so id clean that down well first.. thats not metalic tho..
Hmm,if your problem here is that all the paint except that under the badge has faded,leaving a darker badge-shaped mark where its been shaded by the badge,its a problem because the paint is coated in clear laquer. You can polish the laquer,cut the surface down a bit so its glass-smooth,but you're not touching the faded paint underneath so it'll still show the shadow just the same.
I cant see any way around that without new paint.
to get rid of the dark none faded patch, cover the entire car in detailing tape or something similar, except for the bit you want to match in.
Leave it in the sun for a couple of years, then when you take the tape off it should all be faded to the same level.
Edited by Rich
:lol:
That would look cool to be fair
