6n open air
hi there all i've decided that i want a 6n as my next car
and i'm think about getting a open air
so what should i look out for then buying a 6n
and how much dose it cost to replace the top on a open air ???
  • Replies 48
  • Views 3.9k
All the bits for an open air roof are dear as you like.
ok thanks how much is the cover ??
I don't know for a Polo but for a Lupo it was around the £500 IIRC. My mate was looking to convert his and swiftly said "fuck that" when he found out the prices of stuff.
ok thanks
what i'm trying to fined out is how much would it cost to fix it some nice person slashed the roof
also is there any common problems they have ??
and where should you check for rust ??
Lower doors and arches seem to start rusting first..
Avoid any with serious rips in the roof as they will only get worse, especially with frequent summer use.
Ring Volkswagen and get them to give you a price on the roof. Find out the part number to cause if its the same as a 6N2 then I might be able to get you one as I know where there is one.
thanks
is it worth getting one the will need a new roof in about a year or so ??
thanks i'll get on to vw and fined out how much they are
so how home much is this one you can get ??
Dunno. Would have to find out.
ok it just if i get one i wanted to know how much it is to replace it just incase
Depends how bad it is mate, you could just tape or cover it up..
i've seen one thats got some holes where the bolts are thay have been taped thought
its also got 130k on it and it a r regs
Mine has a ver minor tear about 1cm long at the very back where it folds backs it still seals properly.
thanks this one doesn't leak at the moment it just i i buy it i wanna know how much is would cost to replace it
I alomost bought a perfect secon had roof for 100 quid but had to pay for something else so missed my chance.
thanks thats a good price
i think the clutch needs doing as wall on this one its got full service history thought and only 2 owners from new
Edited by BSJ1
right just got back from ve and it cost just over £600 just for the roof cover :shock:
Sounds about right.
so long as the mechanicals of the roof are ok, you could get a fabric roof specialist to make a brand new hood. you'd still be looking at a good couple of hundred pounds though.
thanks
the runners are about £400 + vat as wall
so would it be worth buying a open air that may need a roof
125k
with full service history
2 owners from new
Work it out for yourself. Its not hard.
Find out the going rate for open airs. See how it compares to the one you are looking at and work out how much you will have to spend fixing the roof.
ok thanks
what is the going rate for open air's ??
I give up.
i've seen some for sell but i dunno how much i should be looking to pay for a good one ??
thats why i'm asking for Club Polo's help
