mk2 polo breadvan.everything is 1 pound each
ripping it to bits.. :crybaby:
I'm keeping :
brakes
camber shims
alternator engine mount
5 speed box and mount
ignition system
body is buggered so no good panels
60mm phil j kit
good bumpers
smoothed bootlid with the rear window surround.
can bring all its to the polo show.
everything else a quid each plus p+p
Edited by polo.6n.max
  • Replies 21
  • Views 840
What round metal bits it got on it?
does it have any goodies or just all standard gear?
it was a country.
dont know rearlly pics below
link to pics
Hi
Was wondering if you had:
Engine mount that alternator bolts to
Rocker cover (3 bolt)
Sump
+postage to huddersfield w yorks?
Matt
Hi
Sump
Matt
hi
need the alternator/engine mount.
got a rocker cover
and sump(bit rusy but dont think it leaks.
15 quid all in?
Got TCAs if they fit a MK3 GT? And the quarterlight bar also if thats the same between mk2s and 3s?
Hi
Sump
Matt
hi
got a rocker cover
15 quid all in?
Sounds good. Currently I'm trying to persuade the gf to go to the polo show so if i get the greenlight could pic them up there?
Will def let you know tomorrow then if not can organise payment etc
Hi
Sump
Matt
hi
got a rocker cover
15 quid all in?
ok pal.
Actually just thought i also need the cam belt covers?? And the plastic bit that connects the engine to the radiator hose (if that makes sense)
Basically I'm building an engine and have none of the anciliary connections
Edited by hirdy12345
You have the jet washers from the bonnet
cheers
cheers
yep ones broken though..:(
have you got the phil j kit for it still
Steering wheel please will meet you at polo show if its going for a £1 i will be in my fairly stock GT SQuare red beast
have you got the bracket that links the front and rear handbrake cables?
yep..1quid plus 1quid p+p
ok deal
pm me a phone number or maybe might not know who you are mate. :-)
how much would you want for the anti roll bar?
Edited by ibizacupra
What engine number or size is it?
If its a 1300 i will have the inlet manifold please
how much for the stearing arms mate cheers
You got any chrome/stainless inserts for the outer door handles ?
