Pic request?
  • Replies 20
  • Views 1.9k
Anyone?
tbh, i'm happy that nobody has, you should be too.
Edited by Rich
agreed, this is the way to the dark side my friend!
cherry bombs,
pipe bombs,
pretty soon it's 9/11.
Can we please not turn this into yet another thread just filled with pointless junk.
aww you deleted our posts...bad times :( you sure jons not on heartys account lol
Jon
Thank you, I want to change the stupid letterbox exhaust that came with my car and i just want a round tip like the one below, but unlike you lot I'm skint and the cherry bomb is the cheapest most normal looking one i can find, unless anyone else knows of any? If i had the money id get a 4 2 1 ss downpipe straight through to the back box from phillj.
just chop off your silencer, weld a bit of straight pipe there instead and get a crappy chrome tip from ebay for about 5 quid... thats what I've done, sounds good, and looks good, very cheap... just need a grinder and a welder, or a friend with both.
from this
to this
Hmm, something to think about doing but surely a backbox is ment to be there for a reason?
well putting a cheery bomb isnt going to be much different to putting a straight through pipe on. The back box is only there to act as i silencer. Like arraon0909 said, weld a straight through piece of pipe there, less restriction to the exhaust gass flow then aswel.
I'm fair sure that all it does is silences some of your exhaust noise through diffusing the air, when i took mine off the noise became just a bit more gruntier, performance was not affected. it's not like its a catalytic converter or anything, doesnt affect your mot when you take it off or anything.
if you where to cut out the back box and put a pipe stright trough, what would the MOT be like ? surly the emissons would be effected?
Edited by 03lochlj
it fails an mot i presume. i ahve taken off my exhaust at the moment sounds good lol, well backbox i also guess its illegal?
pigs with tug you over the noise, will probly pass an mot as the silencers dont really effect emissions.
hey up, i posted the above picture of the removed silencer exhaust, just had my car MOT'd and they said absolutely nothing about emmissions or noise or anything... there's certain limits to how noisy a car can be, cars usually have more than one silencer, so taking one off just makes it sound gruntier, no worse for the environment (unless you count scaring pensioners) :-D
and to withers: it's not illegal.
Edited by arron0909
Glad to see my car can be used as an example :) :)
good times, i may create a custom side exit with just an extra bit of pipeing, is there anything illegal about them?
side exit is totally legal, that's what i'm going for next :-D
the only restrictions VOSA puts on side exits as far as i know is that it can't stick out further than the widest point of your car (not including side mirrors) so basically, you'll get away with it sticking out about 1.5 inches before it gets iffy.
ie. something like this would be fiiiine:
thumb-85-1088-roush_performance_f_150_04
Loads of LWB vans have side exits
nothing wrong with side exits, as said perfecly legal as long as dont extend beyond widest part of the car body.
In regards to emission and having no silencers, eg middle box and back box, this does not affect emissions, it may be illegal due to the decibels of noise produced (not too sure on the legal limit) but this is very unlikely to create that much noise, removed both my middle box and back box and welded straight through stainless pipes, sounds awesome for a diesel, smoother acceleratrion can certainly notice the engine breathes alot better and have had no trouble from the po po.
