new to the seen :)
I'm grant I'm 17
i have always had a love for old school polos
a friend of family has just told me he has a "A" reg MK1 polo he is willing to let me have for £100
it has a full service history but no MOT and has been in the familiy since new i am going to view the car next weekend
it has been stood for a while, is this a problem ?
would you be able to help me with questions i should be asking befor i buy it please
i would be very greatfull :)
  • Replies 23
  • Views 985
A mk1? You lucky sod :lol:
I'm sure all the brainy people on here will be able to answer any questions you have.
Welcome to CP :thumbsup:
welcome too CP
Get it its cheap and simple mechanics
I do think an A reg is a MK2 might be wrong though
am i right in thinking a A reg is a mk 1 or is ot a mk2
A reg will be a mk2.
cheers mate :)
what questions should i ask ?
Basically, id look for rust on the arches, near windscreen and if he knows how to crank it, Do that :@ if its been stodd for a while it may be seized ad thats the worst scenario, or if it has a battery make sure it connected and get you mum/dad or the seller to attempt to jump start it
Thats me out
is it a big problem if it has siezed up ?
Id imagine so, In the sense of a new engine (i think) your best waiting for someone with more knowledge for that question to be answered
yeah new engine pal
cheers pal hope it aint :(
what else should i look for m8 ?
listen out for any knockin if you get it started and driving and whinig from the gearbox, rust, check oil cap for head gasket damage (white gunk) and just the usaul stuff mate.
Mk2's are pretty bullett proof especially the early ones. you need to find out if it is a 1.1 or 1.3 and a coupe or a squareback. they are prone to rusting in the battery trays and the fuel tanks, so those are areas to check, otherwise the early ones are generally very good.
you may get some problems with dirt in the carb causing running problems if it has been sat around and possibly the handbrake would have seized, but i don't expect there will be much wrong that a some new petrol, shot of redex or carb cleaner and some driving about wont fix :-)
Ola and welcome :)
helllo n welcome to the bunch :)
Jon
rust, rust and more rust.
shouldn't be seized at all.
Its not likely to be rusty,the first MK2's were well protected.
Attention is more likely to be needed with things like brakes,wheel bearings,cosmetics,general servicing really.
Sling it through an MOT and see what it fails on,should be quite trivial stuff. There's plenty of help here if you get a daunting list of fails.
Get some pics up if you can.
Welcome mate!
A reg is definately mark 2! is it a coupe or a squareback?
welcome to the SCENE! (note spelling)
Edited by g40jon
what are parts like to get hold off?
Well the car was made from '82-'94 with a heavy technical revision in '86 (this confuses people because the car looked the same,but almost everything was changed - new engines,brakes,some electrics,steering,suspension changes etc to replace the pre-86's MK1 '75-'82 technical set up),and then facelifted in '90 with catalyst/injection fueling and brake servos also added to the post-86 cars.
So though yours is a MK2,it is effectively a MK1 with an early MK2 shell - the most solidly built Polo's known,and the best imo.
Still,most later technical parts can be transferred as a whole even if they're not identical (so an '83 spec car can use many '93 spec parts,but you'll likely have to convert the whole item/unit/system from a scrap car instead of just the worn part),and whilst some early stuff is getting rarer,there's still a huge new and used compatible parts pile to keep us on the road for years to come - and most of it is dirt cheap.
thanks m8 :) what will it be like for me on insurence?
-check the arches for rust... and run your hand under the arches and MAKE SURE the dirt and crap falls out... so that you know if the dirt is covering any rust holes!
-also rust around the windscreen and rear window
-and battery tray
-make sure the battery clamp isnt corroded
Sean
x
welcome to the club mate :-D
if you dont want it, ill have it :-D
