Sunroof transplant!
I have the clasp version sunroof in my 6n would I be able to change over to a windy one a al 16v???? Without bodywork! Cheers
  • Views 781
i fitted one on my 6n, if you just want a clasp one its a piece of cake.
I looked into a slide one and i would say unless you are an awesome coachworker its impossible. I think most slide ones are factory fitted.
yeah they are factory fitted and usually involve a big tray full of bits welded & bonded to the inside of the roof. It'd be a serious amount of work to retro-fit one. If it's even possible as the roof skin normally has lips around the sunroof hole which are welded to the tray that holds the sunroof. just get a glass sunroof panel which lifts completely out.
i have the clasp one, i thought it might be the case!, cheers guys
