Number Plate Bolts
Hi,
I'm having a problem with my rear number plate bolts
I tryed to remove them this morning as they snapped cause they were rusty
now the rest of the tread is stuck
Does any body know how to get them out
I've took the cover off from the inside and that does seem to do any thing except spin them and not undo them
Many Thanks
James
  • Views 744
i had this problem mate,
you'l have to cut the washer type thing off that you can see in your pic and the botl on the back will come off then,
when i put my plates back on i just used some normal bolts with a bigger washer either side
Cheers Mate
I will try that now !
:thumbsup::finger:
i just kept bending them and then cut the lumps and made them smooth and fitted pressed plates with pads:D
