Mk3 headliner removal
Anyone got any tips on removing the headliner from a Mk3 polo, as I'm re-trimming it with some suede bought off Babz_s. anything i need to be particularly careful of?
Thanks in advance!
  • Views 1.7k
it's glued on the pillars and underneath the window rubbers so try to heat it if poss. the worst part to get off is the rear pillars(by the boot)
For the rest just make sure u remove everything ie visors, grab handles etc
edit: there's also metal rods going across the width of the car u need to be aware of
Edited by aroncmc22
is it not the same as the mk4?
dunno..why what difference would that make?
because you dont have to use a heat gun atall, just take grab handles and sunvisors off then the grey trim going along the rear then pull off, no glue atall
