Airbag Deactivation
Could anybody shed some light on a small query? I would like to fit an aftermarket Momo steering wheel in my 96 Mk4 6n and would like to know if anybody knows how to deactivate the airbag system?
Any help would be most appreciated
  • Views 1.2k
dissconect the battery for about 10mins before hand, on the rear of the steering wheel are 2 torx screws (i think there torx) undo these and remove the airbag as one unit. be careful with it and you should be fine. I have personally done 3 now like this and not had one go off. Put it somewhere safe where it wont get kicked or dropped and dont throw it in the bin.
Very explosive charge in them
Many thanks, but could I ask does just removing the Airbag actually disable the dash warning light as well? Or is there a relay or some such to disable that part of the system
it wont you will have the light on. depends on the dash but if i rember correctly the older shape dials you can remove the bulb if newer id like to no as i would like to fit my momo without the light being on,
You can do roughly the same thing with the new dials, I believe they use small LED's? Couldn't you just use a pair of needlenose pliers and pull it out?
Or my next best DIY trick...cover it with electrical tape? :lol:
As above disconnect the battery and leave it for a while, once you've removed the airbag put a resistor on the end of the plug, i think its 2k2. That should stop the light coming back on once uve connected the battery back up and it should save you the hassle of resetting the light/ removing the LED.
Hope that helps!
Ussy
Try removing the airbag fuse. Sometimes works on some cars, all depends on how it is setup.
