Broken Door Lock
Help!! I have run out of ideas, my rear near side door lock pin seems to have become detached inside the door in the lock position, while shut, anyone have any ideas how I may be able to get the door open, once it's open I should be able to whip the card off and have a peak inside...
Just doesn't seem to be my lucky week :-(
Any ideas would be most appreciated
  • Views 668
this happened to me the other day,
heres what happened, the pivot point is only made of plastic and tends to snap out of the door location.
i had to pod the door card off with a screw driver and cut the waterproofing sheet to get to the pivot where the vertical locking pin joins with the horizontal rod that pulls the lock free, i could then open the door and fix it.
to fix it i tied some thick wire through the hole in the pivot and twisted it so it doesnt come loose. after this i put the door back together and its working fine now.
hope this helps a little bit, Lewis
Thanks for that, did you manage to get the door card off while the door was shut still? Silly question I know but was unsure if it could be done...
