I've seen some pikey work in my time, but...
this is the best so far
rattled the steering on a car i bought, and it just didnt feel right
felt underneath
ah
  • Replies 22
  • Views 2.3k
it looks like solder, even though it probably isn't.
i hope it isn't.
but who in their right mind would weld a steering column????
and more to the point, how do you sheer one?
this car is for the girlfriend, and I'm glad i found it coz if i hadnt, well god knows what could have happened
I have no idea why you'd need to do that.
maybe in a hoopty dash conversion but that's all i can think of.
i cant remeber doing this but looks like some of my work acording to some , does the car have a toe bar and a weired smell of wet dog from the pikey previous owner :lol:
Scary shit. bet you feel relieved that you checked it over!
lucky to spot that, anyone else could have driven it, hammered it then to find they have no steering!
A buddy of mine had a mk3 golf and was doing 70 comin from a dual carriadge way into single file traffic as he tried to steer into the single lane his steering wheel kept turning and fuck all change in direction! Reslulted in a serious crash probably caused by this kind of dodgy bodge job! Dunno how people sleep at night!
used to be on clubclio when i had my mk1 and when ever the steering column went the first piece of advice they gave was to go and get it welded!!!
god bless renault
I'm surprised the car held together long enough for the steering column to break. :lol:
my polo seems to have the same kind of bodgery to it although they placed excessivly large tube over both sheered ends and proceeded to try and make the welds look like popcorn
thing is... what else have they 'repaired' like that????
I have a 6n diesel a few years ago. idiot had put a petrol gearbox on it... that didnt last long. and power steering piping had rotted so they had cut out the bit with the problem and just jubilee clipped a bit of rubber hose on. first time i went on full lock the thing just popped off.
~I fixed up what i knew about, and got rid of it, cos i didnt want to find out what else they had doe a bad job of repairing.
god bless renault
the welds are probably stronger and worth more money than the renault racks :)
Jon
well my thoughts exactly so i have been over it completely, brakes stripped, new brake lines, which were rotten too, and the flexis insecure, rear drums not set up right
its scary to be honest!
Coh! lucky you found that. But was it the old owner bodging it or it was the garage they were getting it serviced/MOT'd at? If it was the garage they should be shut down! That could've been your girlfriends life on the line. Not surprised you're checking over it now!
looks familiar :lol:
Quality job,that..
bit of solder and soldering iron, job a good'un! why spend on a new colum when u can get a porper job like this done :lol:
But on a serious note, well in for findin that.
I dont se whats wrong? welding steerings colomnor not, I'm sure there was a test about saying an inch of weld was strong enough to lift a tonne.
People weld drive shafts all the time with engine swops so the thought of it doesent really bother me, the level of the work may do however....
welding a steering column is more risky than welding a drive shaft up though...
and the workmanship looks shoddy
theres nothing wrong with welding a steering column so long as its done correctly( using a sleeve over the join and properly welded at both ends) and to a good standard,
that however isnt either of those things, well spotted.
indeed, a well done welded repair is fine but that is a mess and an accident waiting to happen!
I had a similar thing happen to me, i was half way through a turn, steering went, took out a concrete lampost and a fence. And it looks like an arc weld to me, and the workmanship is well... well its shit. Good Find.
