VR6 LEATHERS TO POLO CONVERSION KIT
I recently bought a set of vr6 leathers for my 5 door 6n.
the fronts are in but the back bench is 4 peice instead of the original 2 peice bench i took out...
i think i need some kind of adapter/bracket to be able to fit in the vr6 back bench.
Any ideas???
  • Views 917
Any ideas???
What I have seen is that you take off the leather from the golf3 back bench and you put them into the polo's back bench. It requires some minor modding but the result was excellent. A while ago there was a how to with a link on another site but I can find it anymore.
i did that swap the leather from the vr6 to the polo ones its pritty easy :)
Edited by Ashi
if you originally had a 1 piece rear bench and bought a split vr6 bench then yes youll need the backing plates from a split polo bench to make them fit nicely. the bottom half will fit straight away...get in touch with someone who is splitting a 6n and just get the backing plates from them and then its easy as pie...just do a search and youll get loads of topics on this
