front bumper removal
just wondering if i would need to jack the car up as I've heard theres some clips... would i be able to pull it straight off or would i need to push the clips from other side without jacking car up
cheers
  • Views 1.8k
anyone!!
If its a 6n then i dont know what clips your on about but there are some bolts and screws that are easier to get at if the car is jacked up.
Now then.. This is what you have to do...
Copied from the Haynes Manual
Jack up the front of the car, support it on axel stands
Remove the indicators, then un-do the screw which was behind them
Remove the 4 screws from the plastic arch liner on each side
Pull the arch liner out a bit to access another bumper screw mounted vertically at the top of the bumper
Remove both of the lower fog light trim grills, then remove the screw that is behind them
Underneath the car, prise out the 4 "very stiff" plastic clips which secure the lower edge of the bumper
Remove the two screws fitted to the panels either side of the bonnet lock, then "with the help of an assisstant" unhook the bumper ends and pull it forwards to remove
Are these plastic clips the same as on the rear bumper? If they are, be aware that you'll have to pull pretty hard.
Also, you don't really have to jack up the car, if you remove the trim you can get a torx screwdriver in there and get it off. If you're like me you can slip underneath the front without jacking up the car. If you've lowered it though, fat chance. It helps to have a torx allen key to get the torx screws at the wheel well out without removing the wheel.
I was in the middle of writing a short guide with pictures but then I couldn't get a few torx screws off and required a bit of drilling through, which I wasn't in the mood for, plus I haven't got a new front bumper to screw around yet, so that'll have to wait. A few days.
Those clips are a bitch to get off. I ended up breaking all 4, haven't replaced them as they don't seem to do a whole lot.
I jacked mine up so I had a bit more space, just made it a little easier.
