Smoothing bootlid
Hi
I recently smoothed my boot using 1mm aliminuim behind the holes and filler over the top,
I have now realised aliminum and steel is not a good mix, doesn't it cause rust?
Should i plug weld the holes as they are very small or should i put small steel panels behind and skim with filler?
Advice would be good
Rich
i'm doin mine over the next couple of weeks,all i'm doin is super glue summat like old credit card behind then fill over,or weld em up then skim with filler.
doin number plate recess too! 8-)
you reckonn its strong enough and the filler wont fall out?
How you doing the recess
i quite like the recess there
Always weld it.
It wont last if you bodge it with filler and stuff like that!
Do you mean the holes for the badges? If so, I just filled mine with weld
I know its a MK3 boot but you get the idea. I just cut it out then welded new metal in for the wiper recess. and filled the badge holes with weld.
Cant remember off the top of my head what the MK2 boot looks like but I'm guessing its similar to the MK3?
2 ways you could go about doing the plate recess, cut the metal that's already there, bend it back out flat then like kinda weld it all together, or just cut the lot out and weld a new flat piece in.
Suppose you could even just weld over the plate recess. But I wouldn't as you may get moisture stuck in behind it.
Cool yeah thats a plan, what do you put behind the holes, copper?
Or aliminuim?
I've got 1mm Ally behind will it stick?
when i done mine i jus stuck a small double sided sticky foam square behind each hole, then fillered the holes,smoothed and painted them and it was fine, stayed fine for two years near enough until i got rid of the car...
