94k too high
HI,
i am interested in buying a Polo GTI 2000, mint conditionand service history however it has 94k on the clock, will this be a big issue?? Also are there any things i should be looking out for when viewing?
thanks in advance
Josh
  • Views 872
look for the usual things, only specialist thing to look at is pay close attention to the gearbox, however at this age it may already have been changed.
Are the pedal boxes not crap on these as well?
90k isn't much really. Only 10k a year.
pedal box could have been done under warrenty, but still sometimes nothing is shown on the car or paper work to say its bin changed
there still free if it breaks.
just stick your foot on clutch, owt nasty will show its self.
90k's not high on a well looked after gti, It will probably need a new cambelt and tensioner in the next 10k tho...100k is a relatively big service at vw.
dont be put off by the wheels..if there the standard rx2's they will have corrosion on the lips - its only cosmetic and can be sorted.
gearbox's as mentioned..go at any age or mileage..if its had one, doesnt mean your still out the woods. It could have been fitted with a straight replacement..so same weak parts refitted.
Drive it, see how it feels...the engines pull ok. No knocks or taps. Most engines whine very slightly..pretty normal.
Suspension shouldnt knock or clunk
drive it on off cambered roads, see it it creaks, possible worn bush's e.t.c. Lock to lock steering. again if it isnt lowered. there shouldnt be any knocking clunking or rubbing.
Bodywork wise..GTi's hardly rust at all...you might get the odd ding or scratch. But there getting on for 9 years old now. Check the panel gaps for how they line up. Should be straight not wonky..get the carpet up in the boot, look for any creasing from a possible rear impact. same up front in the engine bay.
if its a lot of money also bear in mind that at 94k, when you want to sell it on, if its 100k+ it might put a lot of people off and not get as much money back
worth bearning in mind
Edited by doug
