euro spec 16v rear lights
Ok guys I wondered if any one can give me the part number for the nearside 16v german spec rear light, (is it same number as our 16v one just german? Also what do I need to do to fit these? Just take the reverse bulb out??
I'm thinkin of using uk ones for daily use but then the german ones for shows!
Has anyone tried the german spec 6n2 nearside lights also? I reckon that would look pretty good, a subtle change to the main stream! Cheers
  • Views 731
not sure about the image code, i just german ebayd it, theres always some on there.
as for the reverse light i wired mine so i have two fogs.
you say you want to swap them for shows :s , why not run them all the time? u dont need a reverse light for an mot, its just gash trying to reverse in the dark
yea i no i dont but its my daily so i could do with a reverse light tbh, yea i cant seem to be able to tell which is 16v spec and which is 8v???
interesting! how did you wire the 2nd fog in? cheers
16v have the black strips going across the red part of the lights.
and for the wiring, i just did it as a series circuit :oops:
ps, if your going on german ebay, try typing gti 6n rear lights, the germans rarely call them 16v, or valver lights, as their top 6n was the gti. just like we dont call them "SE rear lights"
Edited by chrisbin
I've been searching using german words and there's tons! Cheers mate!
