Smoothing rear wiper hole
How have people done this, or seen it be done?
I am scared that welding a plate behind it will cause the thin metal of the tail gate to warp under high temperatures.
How well would fiberglass under filler work?
Any suggestions would be welcome.
Thanks.
  • Replies 9
  • Views 1.5k
I reckon if you go short n sharp with the welder you won't have a problem but make I would do a bit the cool it all off then do abut more, cool it off, etc
The fiberglass method apparently cracks n falls out
maybe you can spot weld some o that mesh stuff to the inside tho and go fiberglassin from there??
I've welded a sheet about 1mm thick, then a thin layer of fibergalss then a skim of filler
just dont got welding all the way round
just a couple of spot welds are sufficient
How about Araldite to stick a metal patch on the inside then filler for the hole?
On mine I welded it with a perfect sized patch with a series of tacks from opposite ends each time so it doesn't get too hot until the spots are joined up then grinding just shy for a skim of filler. I even did this method with small holes for the spoiler thing.
If I do it again I'll make sure i don't have any high spots of metal because it is easy to rub off your primer back to bare metal when your hoping to apply colour. As a result of this I applied U-pol etch primer on again which didn't react well with the tetrosyl filler primer causing cracking. Still all needs rubbing down and re-sprayed lol.
Painted hammerite on the inside and bilt hamber cavity wax where I couldn't get the paint brush.
Well I got bored earlier so just went for it.
I decided not to use a welder as my dad gave me a seemingly good idea.
I sanded down the areas on both sides around the hole, placed a small amount of filler on the inside then held on a square of metal gauze. When the filler had gone tacky I applied more filler over the top of it and left it to dry.
Once dry I cut and sanded some of the excess filler and applied it to the outer shell. Dried, sanded. Dodging in between rain storms... bloody english summers.
I might have to wait until tomorrow now to paint it which is a shame, but I'll get out if there is any chance weather permitting this evening to apply primer. Are there any adverse effects of leaving bare filler over night in damp weather?
yes the filler will expand! you really need to do it all in one go trying not to get it wet at all
*runs downstairs with primer...*
That wont be enough either - primer is porous and can harbour moisture,so it should be sanded off if it gets wet.
Yeah I know it is. Weather wasn't as bad as I thought it would be and during the rain it was covered with plastic bag and electrical tape and ended up reversing it in to the garage yesterday evening where I applied the first few coats of paint.
Rattle cans from VW are dreadful by the way, horrible finish. I think I may rub it down and go to get the current condition of the paint matched. But I am not too happy with the shape/flatness of the filler anyway so I may be rubbing it back down again anyway to reapply the filler.
