Steering wheels 6n2 1.4 tdi
I was wondering if anyone knows how to take the old one off I've got a momo one to put on
  • Views 530
Turn the wheel 90 degrees to one side, pop a small flat head into the hole at the back on the top, your trying to push down on a small clip that holds the airbag in, then rotate the other way then do the same, then theres a huge bolt in the middle which you need to take off.
Remember to disconnect the battery though for 10 mins before you start fiddling with the airbag.
