anoyone no mpg?
any one got any figurs about their mpg?
i managed an average of 40 on the motorway at 60 so what is yours???
Edited by captin_urbis
  • Replies 19
  • Views 1.9k
38. 1.4 8v
14 - 15mpg. 1.6 MX5.
After spending a shed load to fix it.
20-22mpg.
Ooer, I thought this was a what is your MPG topic? Is it?
Edited by Quinny
Look in your VW book, it says in there. :?
how do you work yours out? Because mine uses ALOT.
Fill it upto the brim with fuel.
Re-set the counter.
When you refill, fill to the brim again, keep the receipt and take a note of the number of miles done.
The receipt will tell you how many litres you purchased (effectively used).
You need to work out how many miles per litre (MPL), simply divide miles per number of litre used.
There are 4.54 litres to a gallon so multiply your MPL figure by 4.54.
An example.
100 miles driven from 10 litres of fuel is 45.4mpg.
(100/10) * 4.54
Edited by Quinny
I get 95ish miles to £10 in my 1.6 GT hybrid thing :lol: Thats pretty much driving swiftly most of the time with some full throttle action too.
20-22mpg.
What? 33 in my 1.6 mx5.
about 33-35 205 gti 1.9/1.6 box
about 38 in my bike carb'd mk4
20-22mpg.
Mine's crap.
No one can figure out what is wrong with it, mechanic friend, local garages, Mazda.
So far to sort the fuel economy out it has had a new exhaust, lambda (O2) sensor, coil pack, HT leads, spark plugs, fuel filter, AFM, timing belt + timing done multiple times by various garages, the fuel tank and fuel lines have been checked for leaks and holes.
I've put sheets under the car to check for leaks, had it up on a lift and checked my self.
The clutch has only just been changed with slave and master cylinder's, all fluids changed every 6 months.
The car used to run slightly lean on idle so I changed the AFM as a last ditch attempt.
The new coil pack and AFM raised the MPG considerably, now instead of paying £30 a week for fuel, it lasts 1 and a half weeks. The old breadvan cost £5 a week for the same journeys.
The only other thing it can be now is the ECU which is more money, as in loads.
I hate this car.
Soon I will watch and laugh as it crumples into a cube.
Edited by Quinny
I have a 1.0 6n2 and I get 130miles to a quarter tank
Time to piss on the bonfire...
56 mpg on the last run, have done 60+ before
Averaging 5 litres per 62 miles (100km) , currently 8.14p per mile (just on fuel)
WIN :-D
Edited by jonPDpolo
I never bother working it out cause its just upsetting.
Around 41mpg in my GT at motorway speeds give or take 10mph!
Well I win for the lowest...I've seen my average at 14 before now...and the very best, on the smoothest of motorway driving was 28...and using OptiMax or Tesco99 it's almost heart-breaking...but then you stick your foot into the carpet and all is forgotten...until you have to fill up and top up the oil again
:-D
That will never happen mate. mine has 200k on the clock, has been written off twice and is still going strong as the day it rolled out the factory.
Think you should get another one and get shot of yours if it is that bad.
well i will work it out on the mway now that i have finally fixed my exhaust and going to give the engine a reet good service/ checks etc....runnig shoit at the mo lol
thanks guys although dint think anyone replied with what i needed....a mk3 1.0 lol
I've never been one for economy...
18 mpg from a 1.3 mk2 golf, 25 mpg from a 1.0 Mk3, 14 mpg from a 1.8 BMW, 30 mpg from a tdi escort, etc
Best cars for fuel I've had are my Saxo VTR and Coupe S, both averaged high 30s and pushed 50 on a run.
well usually i wouldnt give a flying fuck, but I'm traveling over 600miles all round trip so i want to save as much money on fuel as i can....more money i save...sooner loon will be driving! lol
