dewipering the boot?
got the mootor out the boot now its just the washer problem, back still wants to squirt water, broke the washer pump aswell, but how did you stop it from squirtin out back, i tried to get one that is front squirt only, but it has a different pin connecter and wont fit or should i just get one for front and rear and just make the rear squirt to the front aswell
hope u all understand
cheers chris
  • Views 815
i simply folded the pipe and taped it up tight and then dropped a screw in the end of the pipe just to make sure not leeeked at all...
Disconnect the tube under the bonnet where it goes to the back of the car?
Just put a screw in the end...
