the work starts on the g40
no you dont.
I'm trying to remeber now when I had one worked........why did I have the valve guides enlarged then to run standard PY valves???
  • Replies 131
  • Views 15.3k
i dont no. did you do it your self???
Didnt the valve stem size change somewhere between 1990 and 94? so that all polo valves then had the same size stems or something like that.
yes some are 8mm some are 7mm
There we go, I bought a 1.0ltr head & had to have it worked by a local guy who did me a shit hot job for £50.
I remeber trying to find an uncracked PY head & it was impossible then!!!!
Didn't think I was going mad!!!!
Best of luck with the rebuild 8-)
Edited by HoppyGTi
Didn't think I was going made!!!!
thanks man. like i sead the 1.3's are the same some have 8mm some have 7mm can be a pain in the ass
was it the early or later heads that changed?
i know early cars had 2 pressure sensors and later only one but what about the valves? the ones on mine are 8mm and its a 92.
Ouch, that piston looks dead!
The powdercoating looks sexy tho.
i dont think there is a set date i think it just depends what vw had at the time. you can press the valve guieds out and change them
Fucked pistons FTL :cry:
ye i no. but this g willl live agen..
Loving the powdercoating... you decided to get them engine bits done then now youve seen mine ;) looks good Ross !
Jake
ye i did jake powdercoating is adictive.
^lol yes it is!
I hope mine doesn't look like that :cry:
dont wory. like i sead bring it up and we cood just do a swop.. :lol:
powder caoting is the way forward..i did wonder if that part was the tank strap thing but decided it wasnt.
i thought you wood have gessed :lol:
its grate saves hours and hours painting stuff and will last longer
i found its actually cheaper in the long run and yes saves hours.. I got charcoal canister holder, fan cowling and calliper carriers done for 10 quid...
that is cheap..
Swap? :lol: You wish baby :-p
well over the past week i have done some more work. got the new valves ground in to the head and put all its bits and bobs back on:
got the bottom end striped and gave it a paint:
someones been busy!
exhaust manifold looks very smooooooth :unibrow:
happy to see the injector jackets going on as the injectors look naked without them.
blocks looking proffesional. you need to get some pistons up it soon. :nod: and get the two halfs back together then its not far of G smile time. :-D :thumbsup:
edit: i thought you were tidying your garage today so you could get the G in, looks very full again :p .
Edited by genesisGT
gave up cleanig richard.
the gt is going to go up to my lock up so there is lods of room in the garage for the g40 and mabby sumit elss :ninja:
Any more progress Ross?
