Removing filler
I've got some nasty looking rust lurking under some filler.
How do you go about removing filler? Hammer and chisel? Sand it all out?
Some light on the subject would be good =]
Cheers.
Mike
  • Views 884
sand it. I wouldn't recommend hammers and chisels, you might poke a hole through the metal if you have rust underneath. Then it's just more trouble.
cheers mate.
Now all i need is for it to stop raining :x
I dont know, knocking through the rusted metal mught not be a bad idea, since it will have to be removed anyway, or else it'll will keep coming back. Be a damn sight quicker!
H&S
Depends how bad it is. If it's really rusty, then yeah, it's gonna have to come out. If it's just surface rust, then grinding it down and using some rust remedy might be enough.
Blow torch!
Bulldoze it!
I'll find out the weekend. Hopefully its just surface rust but there looks to be a boat load of filler. Might have to get the welder out :D
Thanks for the help!!
