6n 1.4 8v crank case breather pipe
any one know how to remove it as i need to replace mine as its split cant tell if there is a clip or somthing on the other end were it ataches to the inlet manifold
Edited by dubbegood
  • Views 789
I'm sure there just pushed on? I don't remeber a clip or anythink.
and don't they connect to the airbox?
Then again mine is a 1.0 but i doubt that it would be differnt?
I second that, i'm pretty sure that they just push onto the air box, cause the fumes go through the air filter. Dont think there are any clips either, not enough pressure to need one
H&S
yup I've sen it just pushes onto air box but the other end isnt lose and is some kind of plastic bit on there found out on removin the inlet manifold it goeas to a oil seperater thing orderd a new hose from vw at about £14
Edited by dubbegood
