leather seats help
just got a set of leather seats off my m8, they were given to me, they are off a merc .... i was wondering what i will need to do to make these fit & also they have the heated seating function .... can this be wired in ... if so how would i go about doing this ???
  • Views 980
HELPPPPPP!!!!!!!!!
you need subframes from 6n seats welded to the bottom of the front seats and back seats probably need shite loads of modification thats if the seats aint to big for the cabin
as for the wiring you should be able to make some wiring up if you know what wire does what on the seats
i only have the fronts I'm gettin the rears re-trimmed in time... i just want to get them in as quick as possible ...
so all i need is 6n sub frames ???
First off I'd recommend taking out one of your front seats, easiest doing the passenger side as the steering isnt in the way, not sure how difficult this is on a 6N, but on a mk3 its just 2 or 3 bolts, then take out the seat completely. Try the Merc seat in, check if its too wide or too tall to fit, if it isn't you'll need to start measuring the width and dimensions of the subframe, and probably need someone to weld up something in that kind of dimensions.... although if they're seats off the likes of an E-Class, you're probably not going to fit them in. To wire up the electrics you'll need to speak to somebody who's done a Golf or Polo Colour Concept seat swap, they are usually heated. Sorry I can't specify more accurately, I've never owned a 6N (yet).... Good luck!
I have some Merc seats in my mk2 polo and they just had 2 wires used for the heating and ajustable mechanism .. One to the battery and one to earth ..
Make sure when u fit them you have them sat as low as possible as when attaching a new subrame you could make the seat sit too high ..
