Best way to sort this
Need to sort my rear bumper out
Picture shows the worst bit, was just going to sand down with varying grits of paper (I've got 240 through to 1500) then mask off and spray
Am also getting a replacement side strip from VW and spraying that
Question is does it need primer? I have a can of plastic primer but want to avoid that if need be due to 24hr drying time and the weather forecast over the next few days
  • Views 961
24hr drying time for plasic primer? i have used it before and it is dry with in 30 mins or so
It depends how deep the scratches are but I would use primer anyway.
If you are using cans then it wont need 24h to dry, just use a hair dryer or heat gun every 10mins for about an hour.
Flat it with your 1500 Grit then try and get some 2000 Grit and flat it with that ..
Use panel wipe and then spray the primer .. Flat the primer with 2000/3000 Grit and then hit it with paint ..
Flat the Paint with 1500 then 200 then 300 so it feels like glass then Machine polish with a cutting compound to a shine and coat with wax as a sealnt ..
What i do for a job now mate .
Where do I get the higher grits from (2000 and 3000) as I've got 1500 but can't seem to find them
Places like Morley's Paint shops Ect ..
Email me you home adress john and i can post some to you as I've got shitloads at work :)
