2 MONO BLOCK AMPS FOR SALE
2 MONO BLOCK AMPS FOR SALE LANZAR AND KENWOOD
LANZAR OPTI D 2000
Mono Block Subwoofer Amplifier Class D
0.5 Ohm Stable
MOSFET Power Supply
PWM (Pulse-Width-Modulated) System
Double Sided Epoxy PCB Circuit Board
Gold Plated RCA Inputs
Custom Terminal Block for Speaker Connections
Thermal, Overload & Short Protection
Remote Bass Control
Soft Turn On/Off
700 Watts RMS Power into 4 Ohms
1100 Watts RMS Power into 2 Ohms
1600 Watts RMS Power into 1.3 Ohms
2000 Watts Max Power into .5 Ohms
2600 Watts Bridge Max Power Into 2 Ohms
THD @ 1Watt/4 Ohm: 0.1%
S/N Ratio: 90dB
Frequency Response: 15Hz - 150Hz (+/-3dB)
Damping Factor @ 20Hz/4 Ohms: 400
Low Pass Filter: 50Hz-150Hz, 24dB/Octave
Variable Subsonic Filter: 15Hz-40Hz, 24dB/Octave
Variable Bass Boost: 0 to 18dB
Variable Phase Control: 0 to 180
Input Sensitivity: 200mV ~ 8V
Input Impedance: 10k Ohm
Line Output Impedance: 100 Ohm
Fuse Rating: 30A x 6
Dimensions: 10.08'' (W) x 2.12'' (H) x 19.1'' (L)
i used it for about three months den it killed my alternator twice so i decided to get a smaller system its got a few scratch marks on the front where it had been rubbing against my rear seats, if you want solid bass this is a must have amp
£270
and
KENWOOD KAC-6104D
Class D Monoblock Car Amplifier
RMS Power Rating:
4 ohms: 200 watts x 1 chan.
2 ohms: 300 watts x 1 chan.
Max power output: 600 watts x 1 chan.
MOSFET switching power supply
Input Sensitivity: 0.2V-5.0V
Cast aluminum heat sink
Speaker-Level Inputs
Variable Low-Pass Filter: 50Hz-200Hz (12dB/oct)
CEA-2006 compliant amplifier
Current Consumption: 21A
Frequency response: 20-200,000 Hz
Dimensions: 9-1/16”L x 7-13/16"W x 2-5/16”H
this amp is only a month or two old used to run to 12" jbl subs and was perfect but it is no use to me any more £75 takes it
pm if intrested I'm based in harrow, london
  • 8 months later...
  • Views 236
