Am I doing it right? Bumper prep work
Righto, the bumper I have is in a mess, I bought a second hand one and it's all straight and I tried preping it and painting it myself, the result is nowhere near the original quality I want, painting outside just doesn't do it justice. In any case, I'll rub the paint off and get all those little holes I missed first time around filled up, but I need to know if I'm doing my prep work on plastic correctly. I'm rubbing as much as I can where the stone chips are, most cases not enough and I then use filler, then plastic primer. In places there's no need for filler but I get down to bare plastic, in that scenarion I just use plastic primer. And over the whole lot I put aerosol filler, it's the motip aerosol filler, it's great for filling in all sorts of surface scratches. It should have primer in it, so I've been told, it's great stuff to get the whole surface smooth. I spray this over the areas with applied plastic primers and spots where I just scuffed up the top coat and got down to the paint. Is this fine?
  • Replies 11
  • Views 1.2k
em, I'm not an expert on spraying, but from what i know, and as far as i know, you shouldnt need to use a a aerosol filler, hae you the hole bumper sanded downdn to plastic?
you do know you need to wet sand it with atleast p1200 paper to get it smooth enough?
then primer, about 2-3 coats. and then paint and laquer.
i dont know what the storie is ver there but in ireland you can only get water based paint anymore, which is alot harder to laquer and get a good finish, to get a rite good finish it'd need to be put in an ovan too.
basicaly, what grade paper were you useing? wet or dry? and did you sand it all down to plastic?
Nope, not all of it is down to plastic, just some bits. Then some plastic filler on the chips, then primer. I'm using anything from 80 wet and dry to 2000 wet and dry. The aerosol filler is a very nice thing, it makes the surface amazingly smooth once you get at it with some 1500 or 2000.
you but you shouldent need it! plus the fact if you dont have it ALL down to plactic youl get mapping, which will look shitty, trust me, just get a rag, thinners and your good arm and get most of the heavy paint off with that, then start with 120 dry and keep at it and at it till you get to useing 1200 then go wet. itl be as smooth at 1200wet as youl need it,
then get a clean rag and some panel wipe, git the bumper a wipe doen with that do get ALL the dust off.
DONT TOUCH IT WITH YOUR HAND AFTER THIS
THEN prime it, 15min between coats, give it 3 light coats.
DONT EVEN THINK ABUT TOUCHING IT YET!
when its fully dry, after about a 2 hours give it a light wet sand down. wiat to dry.
go out, get another dry clean lint free cloth, damp it with panel wipe and give QUICK wipe down and imediatly dry off or els it will eat you are primer.
now you can paint it, yet again atleast 3 light coats to get a nice build up, leave to dry
DONT TOUCH
now same with your laquer. LIGHT COATS is vital, your best eing able to leave the bumper beside some heat, nothing mad hot, just to help it dry abit quicker, like i said, by rites you need an oven.
I'm not doing the painting myself, aerosol paint won't look as good as getting it done profesionally. But I'll just prep it myself. I want it to look mint, and I don't have a garage to work inside, so I'll just suck it up and pay somebody to do it well, instead of me doing it shabby.
Well, time to get rubbing, this time very hard.
Edited by MehMan
sounds like your making really hard work out of this!!
you need to get it all smooth, if its not smooth, the finish is going to be crap, you need to sand the entire bumper down if your going to repaint it all, iv done small touch up jobs which have turned out awesome but the full bumper job i did just wasnt that good :-(
just take your time, theres a couple of guys on here who do there own painting, go through the photo gallery youll find stuff in there
I've just sprayed a full door. And its looking good. Just needs a cut back
Basically fill your holes and primer like you have. You should'nt need to rub down to 2000. In fact its likely to be too smooth. I went to ~1200 before spraying the top coat, so rub the primer down to that in progressive stages from ~600. The key is to making it smooth, but make sure you primer it all. The finish of primer is quite good for finding any spots you've missed.
I have no idea what matey boy is talking about using thinners? that wont touch the paint. Unless he means cellulose thinners. And you shouldnt need to laqure either, but your getting it finished professionally anyway right?
So basically fill holes
Rub all over ~600-1200 grit
Primer
Rub again ~600-1200 grit
Take to body shop
Remember, just make sure its all smooth!
H&S
whose matey boy? that suposed to be a dig or somethin??
its to clean off any dust or dirty paw prints from sloberers touching it,
in fairness he didnt even sand it all down ffs..
and like i said, you need to laquer WATER BASD PAINT, retard, tinners will eat away the primer, but wont affect the paint, water will wash away the paint after a while. its because its WATER "BASED".
you do know you just repeated everything i said? pointless post realy..lol
^^^ oh my F***ing god...it wasnt a dig, he probably couldnt be bothered to check your name while writing his post.
tbh i dont really see the point of using thinners, just wipe it over with a cloth...hes having it professionally done, just doing the prep himself.
chill out mate
tbh, you're all cheap.
Just pay to get the whole thing done, it's only a bumper.
i am chill dude,
i ment wipe it down quick with thinners or preferably pannel wipe between coats of primer,
IF it was touched, ie moved from uotside to spray back into heat inside ect ect, natural oils on you skin can contaminate it..
ha spose, but recession, and i didnt see the point in paying €250 to get it sprayd when its only a 98 1L, so did it myself for about €50.
chill out mate
you his wife? lol only joken mate :lol:
