Halfords paint
Ok in halfords they do little 250ml tins on paint, on the back of the tins it says that it can be used with a spray gun and compressor mixed with the right enough of white spirit?
http://www.halfords.com/webapp/wcs/stores/...tegoryId_165495
Is that rite? you mix it with white spirit? I though you mix paint with thinners? or are they the same?
damm I'm confused.
ok so I want to spray some alloys gloss black and want to use this paint.
Has anyone use this paint with a spray gun and compressor? oh and with white spirit or thinners?
Or
Would hammerite tinted paint work? when its thinned that is.
Edited by iDan
  • Replies 12
  • Views 1.5k
cant you just use the spray cans? its soo much easier and i know loads of people that have used them and they have come out fine
yeah me, you idiot lol
i dono just want to use the spay gun, just to give it a try.
you want thinners not white spirit. any paint within reason will spray through a gun if sufficiently thinned
nice one cheers.
Have you dont this before and how did it turn out?
Turns out much the same as a spray can I'd imagine...
Well the quality of the paint is fine for me, just a spray can dosn't atomize it as well as a spray gun?
either way just want to give the spray gun a try.
When i used to to spray cars/bits and bobs at the garage i used to work at i always used the gun, personaly i find it much better, you get a much finer and adjustable spray(depending on quality of the gun) I've used cans many times but it will never beat the quality of a proper gun.
as for thinners/white spirit....I've never touched white spirit....id advise thinners as thats what i normaly used. you can buy a small tin from halfords for a rip off £7 or wilkos do it for about £3 quid
hope this helped :)
mat.
yeah it did matt thx, on the halfords tin its says to be thinned with white spirit? ill just use thinners.
I'm going to go for hammerite, it says you don't need primer for it, and i know there good.
no worries mate, and i suppose its good to go for something you already know :)
mat.
most paint in tins should be mixed with thinners, even stuff like 2pac if you want to get it through a gun, I've never used white spirit might try it some time but not on my car :) i guess it would thin it down but isn't white spirit oil based?
I have no idea, I though they were all the same as terps,tinners and white spirit. but hey I dunt know crap.
White spirit IS paint thinners.
