Polo 16v 6n
Hello
I'm looking for some info on the polo 16v as I'm looking to get a little run around for back and fore work.
Just after some information on common faults, reliability, fuel costs and what the car drives like.
  • Replies 21
  • Views 2k
Check gearbox thats prob most common fault.
Bout 45/50mpg if u drive really smooth and to the limits
Great to drive lowered.. but standard they are bit top heavy i thought
but they pull like a mofo and are so sexual :)
Best of luck getting that MPG - 4k RPM is tooooooo addictive. :D
i know lol but if u drive below it you can get it :)
If you're gonna drive that carefully you may as well get a 1.4 cl.
I can get around 40mpg out of mine not driving like a granny at all.
If the car is well serviced and running right you shouldn't really be dropping below 35mpg.
Trust me he doesn't infact its very rarely under 4k. :lol:
Twincam :D
16v have to rev the tits off them to get anywhere same as any polo.....
Pull like a mofo are not exactly the words I'd use to describe a valver...
Reliability wise.. Engine - top notch if looked after... gearbox.. prone to going even if regularly checked/toppd up with oil
Fuelwise like any car it depends how you drive it...
mine pulls very welll compared to most cars I've driven
Valver engines are wierd and need lots of attention to keep them going strong.
I've had 3 and all have felt completely different. If they have been looked after properly like my first one then they do pull very hard and never ever go wrong.
If they haven't been looked after or been looked after badly i.e. used cheap parts as replacement instead of VAG then they do suffer and can become tired and tempremental.
45-50mpg??? HA! Not even careful driving will get you that mate! Someone has a dodgy calculator...
My 1.4 can do about..... 100 on a tenner more if i really go like a granny.
I got a ball hair away from 48mpg in my valver last year on the way to the Polo Show. It is very very possible to get 50 if the car is running spot on.
There's quite a few people on here who struggle to break 30 mpg with their valvers! I've got first hand experience of the man above's car getting nigh on 50 mpg! But then, he broke 50 mpg in a Mk2 Golf GTI!
Maybe I can actually drive. Think I might make myself a challenge one day and get a car thats supposed to be uneconomical and get good economy from it.
You failed on that front, remember when you borrowed the is?
I mean a fully functioning car thats ment to be uneconomical as standard. Not one with a fucked lamda sensor.
Haha, ok. How about you borrow someones scooby do and see if you can get 40 mpg on your commute!
Deal!
Anything goes wrong with it to do with engine its more expensive for parts as they are different to the 1.0/1.4 polos I've found out the hard way
