Bad day yesterday... but wierd conversation about wheels
So, story starts early yesterday when my brakes failed- front hose had gone the journey. So i limped home, and booked in local place to get hose replaced. Went to take car over and it wouldnt start- rubbish! turns out that was a simple electrical fault, so made it round and got brakes done. Good job i had £75 going spare... hold on a second, i didnt!
Anyhow... point of the post. At the local brakes place the guy (who didnt seem impressed with it being lowered as well) said 'are they the right wheels for the car?'
They are aftermarket, but came off a Polo I bought, and I have had them on 3 different 6n's now, and a Rover 25.
Then he started saying that you get different spacers on wheels and they dont fit all cars.
The way I understand it you get different stud patterns, but if it is the wrong stud pattern it wont fit, full stop.
Likewise you get different size bores, but there is no problem there.
I have never had any problems fitting and removing the wheels. So basically i think the guy was talking out his rear.
  • Replies 9
  • Views 1.8k
yep talking shit. unless there 4x98/101 which you can run with normal bolts at a push
At a push,i hope,means with collared bolts..
Spacers? Did he not mean the offsets vary,and so you may need spacers for some fittings (Vauxhall,for example)?
sounds like he's talking about offset but if they don't catch then there's no problem?
I think he would be refering to the centre bore.
depends if it needs spigot rings or not.
Maybe he meant spigot rings,yeah.
your front hose failed? how? either perished (should be picked up on previous mot i'd say) or rubbing - either way not good!!
He could be right, spacers adjust the offset, without these, your tyre might be catching the flexi, which is bad shit.
sounds like hes on about spigot rings. they hold the wheels central on the hub.
my fault with hose, i did the brakes last weekend, painted the calipers etc, and when i have put it back together the hose was resting on the drive shaft.
Could have been a lot worse i know... and lesson learnt in that regard!
The bore seems to be spot on, the wheel fits over the hub just right, and the bolts all line up without a problem, not like the bore is loose and wheel move about until bolted on or anything.
Its just the wheel bolted straight on- no spacers or anything.
