mk3 gt keeps cutting out
my 92 gt keeps cutting out when i press the clutch at traffic lights and stuff like that.
it idles fine, has no other probs apart from a cv joint needs doing.
i doesnt always do it either, doesnt seem to be affected by weather.
I've checked threes no air leaks in the system and the air flow is fine, the fuel system is all good to?
the only thing i can think is that the fuel filter is blocked, as I've ran it to almost empty recently.
i know with sciroccos that the tanks rust and then block the fuel lines (which happend to mine)
does this happen to polos?
  • Views 894
mine did this after i ran out of petrol :oops:
i changed the fuel filter but it still did it every so often, so i changed the blue temp sender - sorted :)
I'd check the obvious signs and go from there... coil, leads, plugs, dizzy cap and rotor arm...
i think I'm gonna change the fuel filter then,
I've checked the dizzy and all that stuff.
what does the blue temp sensor do to the fueling?
i dont know loads about injected engines.
tbh I've not got a clue, PhilJ told me to do it, and it worked :D
