removing side bump strips
Hi guys,
I'm taking my bumstrips off today, just wondered the best way to do this?
i was gna use:-
hairdryer
credit card
white spirit
this the best way?
BUT...
how do i blend the paint, because i have a feeling, since the sun has gotten to the paint work it has faded, and underneath the bumpstrips its fresh paint from factory!
  • Views 982
i have found spraking them in wd40 then a bit of fishing line to cut throw the glue betwean them and the car then more wd40 to get the glue off the car.
a good t cut shoud blend the paint in
cheers man, il give it a go tomoz, was going to do it today but thought id fuck the paint up.
what t cut should i use? the white restorer? I've used t cut on my fiesta before and it made the paint swirl! :S
not shore wich one. yes a light t cut then a good polish shoud be ok
kool kool il give it a go, how about white spirit?
No, no! theres a much easier way mate. Theres also a section in the faq about this.
Basically boil a kettle to ALMOST boiling. Then pour it onto the strips as you lean on them slightyly (just to let the water down the crack. One end is normally enough, so that you can get a grip on it. Then just pull it away, should be fairly easy. You may find they have already started to come up at the end of the doors anyhow
Though i do like the fishing line idea
After this, go grab yourself a fudge/caramel wheels. Basically a rubber wheel you put on an electric drill. This should them take any gluey residue off. Your local body shop should stock them, not halfords though :-D
I did mine a few weeks back, and i would not have wanted to do it with thinners etc. Would have taken so long. The wheel may leave a yellow residue. However, NORMAL T-cut should take this off
This way will save you so much time, but beware with the fuge wheel, if you hold it in one place for too long, you will melt the paint, so keep it moving, and stop now and then to let it cool a bit
Let us know how you get on!
H&S
