6n windscreen
how do you remove / refit?? front windscreen and rear 1/4s???
cheers
  • Views 709
does any 1 know????
i can only say from my own experience but this was with a corrado, they are bonded into the recess and i spent around 2 days with a cheese wire cutting through the bonding, i got all the way round and at my last corner, bottom of the a pillar on drivers side it cracked! i ws sooooo annoyed!
they are bonded in and i dont know if there is a special tool to use, but i used a thin peice of wire and it took me a very long time, to cut through the bonding. Good luck.
i have seen bonded windows removed on machines (ie cat 230)that was done with a soldering iron and a hole drilled through the tip and a woomen handel on the other end an used in a sawin action but to put them banck in i have no idea hope this helps a little :-)
