mk2 breadvan -80mm pic request
as per title, i have ordered a -80mm kit from germay and just wondered if anyone has actually gone -80mm on a mk2 breadvan???
If so, can you share your pics please
Gregg
Edited by LregG
  • Replies 26
  • Views 7.5k
Gregg
do you mean up? mines dropped 90 if you uwant to chheck my tthread out.
Checked your thread mate, looks more like a 60/40 drop to be honest
Edited by LregG
This is 70mm I think on my brothers' mk2. I think he is 80 at the rear though?
Weitec kit BTW
Gregg
mines dropped 80 front and 60 rear on philj shocks and springs mate
mine is 80mm with lowering topcaps.. and 70 at the back i think ? maybe 60..
Edited by jimmy7
The front could do with another 10mm and that would be my ideal mk2 breadvan stance i reckon...........god knows what i used to have on my old G40 (was ment to be -60mm) but that was lower than another G on coilovers!!!! The drivers side track rod end used to hit the inner wheel arch over hard bumps......it was that low lol
Does it rub at all jimmy??
Edited by LregG
i know man, but coilys are just too much :(
i had a weitec 60/40 kit on my GT when i bought it and that was lower than the 80mm springs i replaced it with, softer springs i geuess..
no rubbing, the rears are the same tyres that it came with and are real skinny and the fronts have too low of a profile to catch :) its alllll good :)
mine just after i fitted it with a -80mm philj kit, so springs hadn't settled
with 135r13's
with 165/40r16's
then i cut 2 coils out front and rear
still waitin on my -10mm top caps to bring the front down a touch more
it hadnt settled fully i doubt yet, its an 80/60 phil j kit with lowering top caps and 13" wheels low profile tires.
i'll get another picture tommorow, i'm insulted !! :(
now they all look quality that low. but any scrapage underneath of cars?
How is it over speed bumps if you are carefull? :oops:
Or any other problems being that low. as my mk3 is -60 -40 and i have to drive over speed bumpt all the time to work BOO
Edited by jmk2g40
with 135r13's
with 165/40r16's
commented on yours on vzi 8-)
I like that a lot, the stance is spot on......what are the wheels off and do they rub at all???
Gregg
that one is real nice ^^^
mine catches the floor alot, i now need a new exhaust because of it
Yeah the exhaust is the only thing I hit, I'm down 70mm.
No need to feel insulted mate, just didn't look as low as it should....which is justified as it hadn't settled when the pic was taken :-)
Gregg
the wheels are off a laguna and are 6.5" wide which is handy as they only just fit between the wheel arch and spring cup with 13mm on, and the rear wheels scrub the inner arch rather than the tyres when i take passengers so gonna have to pull them a tad more.
i cut my centre box out as that was the main thing that hit the road, pretty sweet now
Did you not have any luck finding the steelies? Or is the spare only a 15/spacesaver.
13mm spacers on the front and nothing on the rear??? Do you mean the rear wheel hits when you have passengers in the back or in the front??
Only reason i'm asking is because they look quality and i need as much rolling diameter as possible as the diesel engine i am fitting will rev to 4.5-5k rpm max meaning 85-90mph flat out with standard tyres.....more rolling diameter will push that up a lot more and give me better cruising rpm meaning better fuel economy
Gregg
Gregg
Sounds interesting. What diesel lumo are you putting in?
H&S
Gregg
H&S
A 1W 1.4 diesel engine found in left had drive mk3 polo's.......i'll be adding a turbo as well :-)
Gregg
H&S
Wow, where did you find that? Good scoop!
H&S
have found a few at random breakers on the internet but with postage costs makes them come out to between £50 and £70 a rim which is more than i've got to spend at the mo as i've just booked 2 holidays
Gregg
i can't remember the offset of the rims but i've got 5mm spacer on the front coz the offset was so far out from original the handling was really bad, and 13mm on the rear. only rubs on the rear with passengers.
only problem with your plan for big rolling radius is that if you're planning on slamming it you'll need to run 165/40 16's which actually have a smaller rolling radius than the standard 135r13's that mine came with as standard meaning you'll loose some top end, and i don't think the big wheels /larger tyres and smaller drop would work quite the same
H&S
In a seat terra van mate
