mk2 breadvan -80mm pic request
i can't remember the offset of the rims but i've got 5mm spacer on the front coz the offset was so far out from original the handling was really bad, and 13mm on the rear. only rubs on the rear with passengers.
only problem with your plan for big rolling radius is that if you're planning on slamming it you'll need to run 165/40 16's which actually have a smaller rolling radius than the standard 135r13's that mine came with as standard meaning you'll loose some top end, and i don't think the big wheels /larger tyres and smaller drop would work quite the same
Cheers for the info, much appreciated.......as for rolling diameter.....165/40/16's are 1.5% smaller than the stock tyre whereas 165/45/16's are actually 1.6% bigger, this is what i plan on using, a gain is a gain lol.
I hear what you are saying about lowering it with bigger size tyres, it'll still look decent enough for me, the underbonnet antics will be my main priority with the car, looks are secondary with this project if i'm honest, it's certainly not going to be a show car anyhow
  • Replies 26
  • Views 7.5k
do you mean up? mines dropped 90 if you uwant to chheck my tthread out.
Checked your thread mate, looks more like a 60/40 drop to be honest
thats breads amazing :-D 8-)
