Newbie
Hi guys.
I'm an ex polo owner, I had a mk3 Genesis coupe with a NZ lump a few years ago. I sold it when I fancied something a bit different and bought a Corrado 16v. I then swapped this for a Golf GTI which I still currently have.
However, I'm becoming a little bit bored of the Golf and have a little soft spot for G40's. My problem is that I do around 1500 miles every month to work and back. Does anyone have any experience of G40's when doing this kind of mileage regularly? Obviously it will be looked after and serviced every 4-5k like I would any other car.
I know the chargers have a bit of a reputation for self detonation. What are the service intervals for a charger running a smaller pulley and toothed belt conversion? What is a sensible power figure to aim for with regards to overall reliability? The pistons being the weakest point if I remember correctly, especially when running larger amounts of boost.
Any other information and advice greatly appreciated.
Cheers guys.
Bryn.
  • Views 535
If you buy a G40 and have no record of it's history then i would have the charger rebuilt and inspected by a professional..........much the same as the gearbox as these (pressuming it has the proper atv or cek) two parts are unique to the G40!!!! Next thing is to change the fuel filter as this generally can get overlooked
So, before you have have even driven the car anywhere hard then this is my recommendation.......this is what i did to my old G40 and i never had a problem with either...
If you are upping power then have the engine checked over first and maybe concider an uprated clutch as most people forget about the fact that this is going to slip when more torque/power is put through it, especially if it's a high mileage clutch.
As for you worrying about pistons, i never killed mine i was running 19psi boost with an eaton and 21psi with a turbo and did not suffer any problems!!!
G40 engines get a hard time for being unreliable due to 'weak pistons' but the truth of the matter is that people buy a G40, do none of the above, slap on a 65mm pulley and a generic chip to suit (this shouldn't really be a problem) without checking out fuel delivery or the state of the engine, thrash thr hell out of it, proving to others how quick a 1.3 can be and then.....melt......"bloody G40's, unreliable blah blah blah" and you either sell the car as bits or decide to go 1341cc with forged pistons as you have become addicted to G smiles
So my advice is this, by all means buy a G40 but have an additional £700+ spare for the charger rebuild and gearbox rebuild and while the box is out, whack a decent uprated clutch in......you should then have a reliable car which has a good basis for taking additional power.
EDIT: one more thing to check is the passengers side front chassis leg, these can crack with metal fatige even with standard engines and also where the anti-roll bar mounts as it has been known for the welds to be shite and the block become dettached due to crap spot welds.......also check to see if the car has been smashed into a kurb, it is not unheard of for the roof to bend or the chassis leg be pushed back either way, not a good car, walk away
Gregg
Edited by LregG
