Removing boot trim (2002 model)
Now then.
I've got a 2002 Polo (with the round headlights - mk5?) and need to remove the bootlid trim.
Even after undoing the screws hidden in the handles, it won't move.
The reason for this is that the wash/wipe is knackered (stuck in the middle of the window), and the handle alone won't open the boot - needs the key to open it. I think something has jammed the handle, possibly a bit off the wiper assembly).
Anyway, I've tried pulling the edges of the trim, and poking it with a screwdriver, but it just pops back into place! I've read the de-wipering threads, and it appears that it should be pretty simple.
Am I missing something obvious?
Cheers!
  • Views 761
Think you just need to give it a good pull.
clips can be a bastard, make sure all screws are removed, then pull... hard!
Was cautious with that approach earlier, as this of thing never seems to go back on the same way.
Thanks, I'll give it another go!
