can you polish scratches off glass
i have been a tw@t and used a scourer out of the kitchen to get some over spray off and scratched the fuk out my rear window , can u use wet and dry , or alcahol and light it ?? apreshiate any help , on a tight ish budget so dont realy want to replace it
  • Replies 15
  • Views 2.1k
Can use t-cut or rubbing compound. Anything you rub paint down with can be used on glass. Practise on a bottle first if not sure.
The best stuff to use on glass is pumise
no you carnt mate
best ringing a glas company up to see if they can repair sctraches in them
glass is differant to paint so t-cut and compound wont to anything
no you carnt mate
Yes you can, screw fix do a gleass polishing kit that fits on a drill for £17.86.
does any one want to do it for me for cash , wont fine wet and dry do it , they arnt deep
Tried that autoglym glass polish?
i have got some good thinkin mate
use jewels rouge
check out this like too eastsidevw. half way dwon the page it shows you a kit that is used by polished bliss. Seems to work really well. worth a try mate.
http://www.eastsidevw.co.uk/forum/viewtopic.php?t=13025
Kuszpit :)
so you fixed one problem with another. or did you not even fix the 1st problem? :lol:
I used some stuff on my old windscreen called glass cutter... worked pretty well. Think I got it from the frauds (halfords).
Nevr knew such a product was available .. In theory it should work although you wil have your work cut out judging on how difficult it can be to remve all scratches from paintwork which is alot softer than glass ..
lemme get this straight u used a kitchen METAL scourer on your window and are now wanting to get the scratches out? , id suggest never doing that again , and using the autoglym stuff tis leet i used it on my corsa " cough " cough"
Last time i asked for that i may as well have dropped my trousers or asked for a motorbike air freshener.
Carlack glass sealing kit, polish/cleaner & sealer.
http://www.cleanyourcar.co.uk/engine-amp-e...t/prod_348.html
Depends how deep they are - try brasso.
Duck Tape repairs everything :lol: :lol: :lol:
