6n2 lights on a 6n
i quite like the idea of banging the red 6n2 lights on my 6n, i hear/read the word conversion thrown about on here which leads me to believe there may be a bit more to it than a simple swap, can anyone shed some light on this for me.
  • Replies 16
  • Views 2.1k
you think too much, keep readin and youl find the answer
And once fitted;
4260_105636264809_509304809_2721943_8230
Should thank Po*Low* for his great effort on helping us!
Edited by LOGiCALX
No worrys mate glad to help
And a photo of mine with the german spec 6n2 rear lights just because i like to be different :lol: *Need my plate's back on :-( *
I really want the Clear Ones like these;
pic from Rolys old mk4.
I have a quick question! I got the 6n2 rear lights today of a smashed up 6n2, and I've got the problems that are described in the other topics, the only difference that there is, is that I'm from a LHD country and have a LHD polo, so do the same wiring changes apply?
Yerr will be all the same if your puting LHD 6N2 rear lights on
So yer same wiring changes
Edited by Po*Low*
Woohooo! Wiring works like a charm! Awsome! Now I just need to trim down the plastic and do the drill. Thanks for the help!
Edited by MehMan
No worrys mate
they look like mine, but a bit more white
Another question! Drilling the middle hole, making it larger, what if mine already fits? As in, I can get the nut on, and all, tighten it, and if I put my fingers behind to check for room, there is none. Do I need to drill the hole?
I never drilled a whole i couldnt see why i needed to..... so dont bother!
Do your's need a wash :p
but do like the clear hella's!
Hmm, apparently it's to make it more flush, which would be great, will have to see if it's worth it. A bit of yes and no I guess.
Edited by MehMan
just get it bolted on as tight as you can, i aint fussed about being flushed whos really that fucking bothered, apart from a proper geeky prat who will come up to your car and oh woops not sitting flush there isit mate not proper scene.... lol, you get the drift!
Hehe, true. The plastic trim is very needed though, it makes fit tighter.
