my babys DROWNING
well basically my passenger footwell used to leak so i cleaned out the pollen filter and tested it, everything went well and i had no leaks....then the problem started, i went into the car today and noticed that the driver footwell was soaked. i can see that its coming from the bottom of the seals by the floor. but when i open the door no water has come from the top but it looks as though the metal base of the door is leaking from inside the door..what is it!!!! PLEASE
Edited by huizit
  • Replies 14
  • Views 2.4k
bump...guys
afraid with leaks its trial and error. my dads rover 75 had a leak i took all the interior out and used a hose on it to see where was leaking. check all the rubber seals and window runners etc would be my advice.
it's probably the membrane stuck to the door underneath the door card. If it's not water tight then water will get into the car. Also check the condition of the rubber seal around the door opening.
try and work out where its coming from - then lightly dust the area of the car with talcum powder - then crack the hose out - the talk will get wet from the source - follow and fix :)
thanks for help guys. i know where the leak is coming from and the seals seem to be in good condition.
but the car seems to me more trouble then its worth at the moment and I'm thinking of just selling it.
bump...
update.....i fixed it guys. I've put electrical tape along the window seal seems to stop the leak.
can you put a pic up of where you put the tape as i dont quite get what you mean and have the same leak i think lol
yeah i will bud, dont think you'll put it there though as I'm not currently driving the car.
ill put the pic up first thing tomorrow morning.
maybe your hymen has broke ?
i originally had black electrical tape running across but a small amount of water was still coming in...but since i just bought a new interior i swapped it for waterproof tape and the problems solved now.
Edited by huizit
theres a membrane behind the door card if it isnt sealed then water will run down the window through the door seal and into your car above the door seal this is what should be sealed:
took me bloody ages to figure out what it was, ended up changing door seals the lot!
thanks for that james will be going scrappy tomorrow
bugger, i haven't got any door cards in mine...
still i haven't got carpets either so looks like ill have to just keep sponging it out lol
