Rocker cover!
i have began to sand my rocker cover down,but i have been told that as its steel you cant polish it?? is this true?
i wanted to do a mirror polish on it if possible.
and does anybody know any easy ways to remove the paint?
thanks
Edited by Phayth
  • Replies 13
  • Views 1.5k
i have seen all sorts of rocker covers polished i think you can polish it! one easy way to remove paint is nitromors easier than scraping and sanding!
on a 1.6?
it's easy to do.
it's painted? you mean there's some left?
nitromors removes everything.
should be like that.
You can polish anything mate. But you'll have to laquer it to prevent it rusting again though.
Use wire wool to get rid of rust, then start at ~400-600 grit and go in several stages to 1200-1500 grit. Laquer. Done and dusted!
H&S
if it really is steel then it'll be a LOT harder to polish by hand than the aluminum cover shown in the photos above. If yours is the 1600 tall block then yeah I think it is steel.
I think your best bet for a good long term finish is to have it chrome plated.
Seconded!
H&S
awesome, where can i get this from? and i half some high temp engine laquer :)
its the same as a mk3 golf 1600 engine.
pic posted later if need be :)
p.s thanks for all the help guys :D
If you can get an ally one, you shouldn't have to laquer it, as long as you keep on top of polishing it
H&S
here are the pics :)
where can i get nitromors from??
cheers
you can order it online, you can get a special auto formula or summit specially for car parts, I've seen it in halfords and various websites!!!
If you want to save a lot of time and effort then get it sand blasted. Doesn't take long to do and gives you a perfect surface to paint on, get chromed or whatever you want to do to it. Will give you a nice even finish all over. Won't cost much to get it done, just go into any local fabrication firm and they will prob do it for you pretty cheap.
just been to halfords its was 4.99 :) cheers guys I'm going to give it a try now :)
i fancy doing this to my 6n i think its a alloy one is it easy to use nitromors and what do you do to get the best results?
oo btw its a 1lt if that helps :D
i just fancy havin a go as it would make my engine bay look abit tidier
jay
