kettle or hairdryer?
I'm going to take the door strips off...
I've taken door strips off before using the hairdryer, but it took alot of time and most of the glue didnt really melt,
one of my friends told me that boiling the kettle and pouring the boiling water down the door into the strips would melt the glue very fast,
has anyone done this before or should i stick to the hairdryer?
many thanks
  • Replies 14
  • Views 1.5k
I tried the HairDryer... failed, try the Kettle as it will heat up the Plastic better, but god sake take it slow or you will be sitting there pissed with paint flaking off.
kettle with an ice scraper
thats what i use done the trick
There is an FAQ for this in the body work section
Hot (not boiling) water as you push down on the strip to allow water in. Then use a fudge wheel to take any remaining glue of. Quick polish and your there.
H&S
cheers for the comments, mods can delete this now, thanks
Be especially careful with red cars when using hot water. I made the mistake of using water that was to hot and it burnt the paint. Basically what happened where the water was hottest the paint faded to pink and the rest of the car was bright red.
From experience heat also fades anodising. I used a plastic debit card, 3 weeks of skin off me finger tips and all manner of autoglym type intensive tar removers. It's a shit job, but worth doing.. until somebody opens there door into yours!
poured boiling water n with a kettle then straight after used a credit card of sm sort behind the bumper strip and it comes off really easy
I'd say hair dryer, because the heat is constant.
I had a load of old pencils with rubbers (as in an erasers) on and they worked really well, better than the kettle, hairdryer and credit card............i tryed them all lol.
Just be a bit careful when youve worn the rubber down, cos you dont wanna be gougeing your paint.
kettle. hot(not boiling) water.
drill.
fudge wheel.
hairdryer personally
henry the hoover.
i thought this was another engine conversion thread. obviously not haha.
i did it with panel wipe and a card worked well for every bit bar naturally the last strip which ripped paint off! gayorz but I've parted with the car now so its all good
i peled mine off and then used petrol to remove the glue
