1980 Series 1 Mk1 Golf GTI 1.6 - Black 12 months mot 6 months tax -
VW Mk1 Golf GTI.
Date of Registration: 10 / 01 / 1980
Engine Size: 1588cc "EG"
Black
Original Sale of Reciept from Forge Garage in Dyfed.
It was bought for list price 4,370 pounds, which equated to an on the road price of £5,688.48.
It was bought in part exchange with a Peugeot 504 JFF 105P which was only 5 years old at the time, and covered just shy of 50k.
It has now had 6 former keepers, with myself as the 7th. I have owned it since February.
It is currently on 138k.
Interior
Period Radio/AM/FM Pull Out with Remote
Twin Pod Clocks with Rev Counter
Twin VDO Guages - Oil Temperature (light needs replacing) / Clock
KoNIG Reclining Fixed Back Bucket Seats - Black/Grey
Scroth Harnesses with Safety Devices Pre-Tensioners
320mm Steering Wheel with Snap-Off Boss
Carpeted Boot Floor
Cut out section for middle floor (requires recovering and unfitted at present)
Newbury Sunroof Centre Aftermarket Sunroof - Tilt only, leaks very slightly round corners with heavy standing water
Exterior
Chrome or Red Stripe Grille - Both Included in Sale
Single Wiper
Amoured Door Plates
Alloy Filler Cap
Silver Stripe
Green Tint Windscreen
Engine
Autocavan World Cup Car Gearbox Mount
Magnecor High Performance Leads
K&N Panel Filter
TSR Airbox
Baffled Aluminum Sump
TSR Mild Steel 4 Branch
Magnex Stainless Steel Full Exhaust
GSF Shift Linkage Repair Kit
MissingLinkz Short Shift Kit
Clutch Cable
Throttle Cable
Throttle Pedal Teflon Bush
New Fuel Pump Relay
Gearbox oil
Rotor Arm
Fuel Filter
Contact Breaker Points
131k - 04/05/2009
New VW Oil Pump
Painted Water Pump
Painted Rocker Cover
Painted Inlet Manifold
Painted Throttle Body
New Thermostat
New Thermostat Housing
Coolant Flush & Change
New VW Cambelt
Headgasket
New Exhaust Manifold Studs /Nuts/Washers
New Rocker Cover Bolts & Washers
15w40 Oil Change + Filter
New Bosch Starter Motor
Rocker Cover Gasket
Sump Gasket
VW Throttle body gasket
VW Inlet Manifold Gasket
Brakes
Black Diamond 239mm drilled discs / Pagid Pads fitted 19/04
Suspension
FK Konigsport Coilies
23/05/2009 - Rear Wheel Bearings / NS Outer CV Boot
Wheels
15x7 and 15x8 Borbet BS with 195/45/15 Toyos/Goodyear Eagle F1s
OR
14x6 Castelletes in White with 185/50/14 Dunlop super stickys
Bad Points
Needs some welding - full outer sill, rear lower valance and drivers rear quarter panels are to be provided by myself included in the sale. all else that is needed is a front lower valance and your sorted
Clutch is slipping due to a leaking crankshaft oil seal, easy job to do once the gearbox is off. Car is still very quick of the mark and evil through the gears which you can nail through with the quick shift, the dunlops have been providing insane amounts of grip when they are warmed up and I've been embarrasing a few cars this week haha
sunroof leaks slightly
scrubs when lowered to the perfect ride height with the borbets on, is an absolute weapon on the castalettes, becomes two different cars, i definatly prefer it with "proper" fitting wheels and some choice tyres any day now.
The car has a full 12 months mot as of last week, and will have 6 months tax as of saturday.
Price
£4,000 or PX WHYG?
If i get my full asking price I will throw the following in for free.
A Spare VW Small Light Rear Panel.
Fully Rebuilt EG 1588cc Cylinder Head with all goodies to put it back together
Fully Rebuilt FP Engine Block with New Pistons
Fully Rebuilt FP 1588 Carb Head
Black/Green Tartan Recaros
Brand New Heat Wrapped Stainless Steel 4 Branch with welded lambda nut and new lambda sensor, welded flexi section
Contact Details
Saf 07816 002 453
Central Manchester
Pictures
This is how she currently stands
albeit running the castalettes
  • Views 496
i have just 1 question how in hell does it have 12 months mot if it needs a new sill!!!!!
Nice rare car here, don't see many small light mk1's about, especially in gti form
it doesnt "need" a new sill, there is a very small hole in the metalwork just by the rear arch, this would be covered by a complete sill panel, or you could just patch up the hole to save repairing the whole sill.
The sills were fully replaced, welded and sprayed to a high standard back in 1995 but a small hole has appeared, as i have a full sill repair panel it would make sense for the welder just to stick complete fresh metal on rather than just repair the one tiny bit]
it was an advisory on the mot =]
Edited by grungeisdead
you got text slag 8-)
