16's on a mk2 breadvan
beany's mk2 breadvan has inspired me to go down the 16's route, so, after some research and web time i found these for reasonable money
I plan on using 165/45 tyres which are a nats cock bigger in rolling diameter than the stock 135/80/13's that the car came out of the factory with
What do you think guys and girls??
  • Replies 10
  • Views 1.9k
have you got any pics of the breadvan with 16's? :)
do it, so long as you keep a reasonably high offset they should go on fine
Should look naughty. The only thing that might look odd is the brakes if they are just standard Polo ones.
Its always about width and offset - His fitted because they're only 6.5in wide,and Renault offset. And still he had to bugger about with spacers for clearances both inside and out.
What sizes are the MG's?
should fit fine gregg, as long as the et is high-ishm, what width are they 6/6.5?, why not go for 165/40's, i'm running 6x16's on my g at the moment, with 50mm spacing on the rear = et 2
I Think the whole car works.
love the green or the brown just not together, and the front needs to come down.......would be spot on for me then.
did nearly do it all brown as i love the colour, but i had a plan in my head and did it.
and yeah the front is comin down a touch IF philJ ever sends the top caps i bought off him 4 months ago :x
The mg wheels are 6.5" wide and ET45......I want to go 165/45 for bigger rolling diameter than stock as my breadvan will be turbo diesel 8-)
