front camber
hey I've recently put some steffans on and my camber on the front has gone mental lol
It was bad when i had standards on from lowering but now its worse.
Anything i can do has its eating my tyres and I've had them a week and half and the inside are getting bald..
Cheeers
Ash
  • Replies 21
  • Views 1.7k
Cheeers
Ash
Hi mate
You can adjust it a certain amount by yourself, loosen off the two lower strut to swivel hub bolts, then pull the strut towards you and try and align it by eye. It wont be perfect but it worked for me and i almost got mine spot on. To get it perfect you will have to go to a garage/carriage works that have camber gauges. Hope this helps
Neil
yeh my sisters bf did that on one side but it didnt help that much
Might do it on other then get it at a garage to do everything :S
TBH, its as likely to be the tracking too. Get that sorted
H&S
OK THANKS PEEPS
camber doesnt kill tyres tracking does!
get it check out son ;)
sound will do, cheers guys
camber does kill tyres! if you've got loads of positive or negative camber then it'll wear the outside or inside edge of the tyre respectively.
inside is wearing pratically bald in a week and half..
i used to go through budget tyres all every 3 weeks on my stanards and they was worst..
at £40+ a corner for tyres on a student budget i carnt rate afford :(
Ash
jesus, tracking and/or camber must be MILES out if you are getting through tyres in 3 weeks unless you are doing several thousand miles a week.
seriously mate they was rubbing on my innerwalls at 1st i stoped that that helped but still shite
Ill get them tracked and see if it helps
I had to raise it to stop the inner wall scrub on standards :(
Pisses me off big time and kills my bank
Fucking student moneys shit But i wouldnt want to be paying if i earnt loads coz its a ball ache gerring it done
excessive camber wears the inner/outer edge of the tyre at the normal rate,
its incorrect toe settings that cause accelerated wear.
and just to note ANY change in ride height affects the camber and toe settings,
therefore if you are going to be yo-yo ing your ride height be prepared to pay for wheel alignment each time its changed.
so if i go to a grage and get tracking done this should sort the problem?
It will help. But if you have a large amount of camber, and dont get it sorted, then you will probs still get extra wear. And as mentioned, get you toe in/out checked too!
TBH though, it sounds like your whole geometry is well out. Take it too a garage, as them nicely to sort EVERYTHING and just pay the bill! :lol:
H&S
:D can they do allignment like laser one with 14x7 front 14x8 rears?
they could do it with 14x50 wheels,
makes no difference dude.
i meant coz of staggered sizes :S
nope still fine
mint cheers buddy gonna get iit booked in as soon as :)
Where can i get some 14x50 wheels? Think they will look too wide on my car? Will they scrub?
HaHa.
Yea longer you wait the more tyre wear you'll have and more money you'll have to shell out on tyres.
Best to get it set up at a height with wheels etc ready to rock then get it set up and dont touch them will be all good then
Steve
Ash
FOOOOK
am running 1.5 deg of negative camber at the front on mine...Not worn the tyres down unevenly one bit.
