1.8t polo coupe at worthesee
hey i was trawling the netweb and came accross this had to double take :shock:
anyone know much about it got the old grey matter going now did he use a subframe or what its sat pretty low in the bay either way looks bitchin
  • Views 2k
Iv seen pics of a few continental motors with big blocks. There's a lush green mk2 saloon with a 20VT in it, looks the business! It must involve making up a subframe and a fair amount of cutting!
that's not a 1.8t, it's a 2.0 abf 16v with added turbo.
the engine is mounted on a sub frame, sumps sits very low to the ground even tho the car sits high...
stunning car, saw it at MIVW in Holland a few weeks back...
Yeah mate I was going to say it's a ABF engine in this one.
A majority only put big block engines into left hookers.
Edited by PiereG40
the 16v turbo polo with a poor interiuer :-D
but....
Golf 16V KR, G60 Steuergerät mit 250kpa Sensor (Bosch), RS2 Kolben/Pleule, Lager, Ansaugbrücke, Drosselklappe, Düsen, Turbo KKK 24/26, Wastegate, Elektronisches Dampfrad (Rothe), Ladeluftleitung 60mm, Forge Pop off, Bosch Motorsport Benzinpumpe, Kopfbearbeitung von SLS, Verstellbares Nockenwellenrad MFT, Eigenbau Krümmer 48mm VA, Oettinger Aluoelwanne (2tlg.), Schwungrad G60 (erleichtert), G60 Getriebe mit geänderter übersetzung und Quaife Sperre,ARP Schrauben (MTS), Sachs Sintermetall Kupplung, CAE-Seilzugschaltung, G60 Antriebswellen gekürtzt, Zylinderkopf poliert (außen), Block und Getriebe in Wagenfarbe, vieeel chrom und Carbon, Abgasanlage: VA Hosenrohr ab Turbo 76mm, 100 Zeller, Kompl. 76er Anlage eigenbau Edelstahl, Töpfe von S-Motors, , Eigenbau Krümmer aus 48mm VA, Alles gewickelt in Thermoband
polo1 16v kompressor.(220bhp)
Edited by richard16vg40
