vw parts prices
i just went down to my local vw dealership to get the prices on a few bits i need.
oil filter £4.06 +vat
fuel filter £9.18 +vat
water pump £37.72 +vat + surcharge
cv joint and boot £ 103.85 +vat +surcharge
thats stupid for a cv joint and water pump, my dad paid under £20 for a water pump for his golf.
as for the cv joint i rang up a local moter factors and the said under £40 with vat
how can they charge soo much?
rant over :-)
  • Replies 29
  • Views 2.9k
they charge that cos only a crazy person would go to a dealer for any of that.
well i wanted the cv and water pump to last :-)
where do you go for your parts?
Local parts place generally. To be honest, CV joint aside, they're not unreasonable if you want to keep your car VW through and through.
The water pump is the one item I've heard that is worth getting from vw. Although I've bought all these parts from independent motor factors and GSF (with Club Polo discount). I've also heard Euro Carparts are worth a look too.
It's all about doing a bit of homework, I've heard that your better getting a vw thermostat housing at which point I'm off down the scrappy. If I had a salary I would probably pay out more on certain parts..
just went to gsf
water pump £26.75 +vat
the filters were a lot cheaper but they dont do the cv joint?
he also said that the price I've got from vw was for a diesel one?
i dint know they put a derv burner in polos in the uk?
so who should i go to for the cv joint?
if your too tight or moaning about vw prices dont go there. I buy everything for mine from Vw because i want to keep the car original...i know a lot of people who think the same. The parts generally are much better quality. The only time i will go else where is if the parts are made by bosch etc you can buy these from many other places so you can shop around. I got a genuine Bosch alternator for my g40 direct from bosch for around 60 quid cheaper than the dealer would have charged me for the same part. As for filters etc..i prefer the genuine ones with the valve in them, to the cheap copies. End of the day like i said if you don't like the prices go elsewhere nobody is forcing you to hand your money over.
Try buying from a Honda or Toyota main dealer... then you can moan. I couldnt believe how cheap parts were until I bought VW/VAG cars!
its not that i dont want to pay that much its thet i really cant afford to pay it at the moment :-(
I've just moved house and am fully skint.
i want the vw parts cos like you i want the keep it original and like you said they are better quality :-)
the water pump from vw are plastic which are poo...ces ones are metel so last longer.
I've never been given a plastic waterpump from vag...
I have,even a Z3 that smashed its radiator up with a broken original plastic one - i bought a replacement from euros and that was metal.
All genuine VW ones I've seen were plastic,and most other parts I've got from euros have been good quality - my battery is Bosch and clutch Sachs,it aint junk.
The new VW parts division,TPS,claims to have addressed the problem but as far as I'm concerned they aint.
I only buy from them what i cant get elsewhere.
I do check euros stuff though - i wont buy anything made in France because their recycling laws mean their plastics are made of landfill.
I Work in a main dealer part dept and I really get fed-up of people complaining about the price of part, I don't make the prices up!
The cost of the filters is right if your not sure about the water pump or CV joint give me your chassis or the part No's and I will check them for you.
As for plastic water pumps yes they do break easy when they are being transported, ordered down 3 once had to send them all back because they had smashed in the box, but once they are in the car they are fine
I fitted one to my GT because the old metal one had rotted.
If you are after a metal water pump find out if the pump is part of a supersession run out? this is when the part is changing from one part No to and other and the warehouse is trying to get rid of the old stock, but what most dealers will do is order the new number because that is the one that ETKA now tells you to use, you don't find out about the supersession run out unless you type a part enquiry into dialog.
personally i've never recieved a plastic waterpump from vw and I've bought around 3 or 4 :?
Just the impeller,not the main body/housing etc.
I'm not stupid i know which part your on about. as i said I've never had a plastic one.
Edited by supercharged spaniel
Sho18k - Nah,i think its just that the company who made the brass pattern part (which doesn't corrode) recognise that the plastic genuine VW ones go brittle with age - my experience with that includes being able to crumble up a removed one with my fingers during a cambelt change.
It only takes an experience like this for me to believe that Brembo brake discs from GSF are likely to be better quality than genuine VW items. That combined with me never experiencing a pattern part fail.
Once down this road,i can no longer be of the view that genuine parts are the best i can use for my car,so the expense is even more questionable. The quality of the cars themselves have varied over time,so who knows about the parts - VW dont want us keeping their old cars on the road,they want us buying new ones.
I dont care if mine is fifty percent pattern parts if its constructed of quality parts.
Dealers depend on their badge (and position with newer fsh/warrantied cars) to overcharge,in my view.
See I'd disagree Mikey..in some respects. I'd happily buy and have done..bought Brembo discs from GSF as I have wheel cylinders which are FAG anyways. But some bits are fucking shit. Clutch cables for example..thinner and far inferior with rubbish rubber grommets that last five minutes. Wheel bearings again rubbish from GSF. It depends on the part I guess. If it's a Valeo/LUK clutch I'll go to GSF and get it cheaper afterall VW will label it up as theirs and charge more even though it's LUK or Valeo. But as for filters and things I'd always go to VW. It really does depend on the part. No need to insult me by saying 'just the impeller' though...there are other people who work on their cars and know their stuff on here not just you...
How long had that part been on the car? What coolant was it running G12, mostly water? These are all factors that we need to consider.
I use (and I’m sure that some people will have some problem with this) BMW coolant, straight (no water) in my GT keeps it nice and cool plus less chance of corrosion.
I would agree with you when it comes to a Mk2 Polo and anything prior to that the way that VW discontinue parts you would think that they don't want us to drive their old cars, apart from the MK2 Golf which you can still get pretty much every thing for.
But I would be willing to bet they make more profit from the sale of parts than cars.
As for Dealers overcharging can't speak for them all but we only charge the price that VW tell us to sell it for so if you find the part too expensive then have a go a VW not the guy at the dealership
Edited by sho18k
Oh get over it for a second post S.S,i wasn't being patronizing at all. I know enough about your experience to know you're no noob,it was a genuine point because I've only ever known VW ones to have plastic impellers,Sho18k even admits they use plastic ones,and so i was trying to consider if id missed something.
But like,whatever..
Still,i agree with your other point on some parts. I know about TPS because i use them - obviously i bought genuine top mounts instead of pattern ones because the pattern ones have a reputation for premature failure. I always use genuine bolts too.
Its sensible selection,and I've made the point about quality,I'm sure some pattern parts are shyte but i know you'd know a good one from a bad one - even if the casing was plastic,as is the case with some other vehicles (particularly electric pumps) its very possible.
I would agree with you when it comes to a Mk2 Polo and anything prior to that the way that VW discontinue parts you would think that they don't want us to drive their old cars, apart from the MK2 Golf which you can't still get pretty much every thing for.
I agree with most of that,but profit made from parts has little bearing on the push to sell new cars.
I've never had a pop at the middle man,some people can be well rude in retail,i can quite believe it.
Cheers for the tip on Beemer coolant,btw. Harrods prices?
The pump in question was on an engine i pulled from a car in the breakers,so i dont know about coolant history. But there was no corrosion to the cylinder head.
The belt was genuine,had seen better days,and the mileage was 74k. So the pump had done 14k more than recommended. The car was a '99 6n - one of the last.
I only noticed because it came off easily - i usually have to hammer the thing off,and previous breakages have been put down to this.
so just coolant form a bmw dealer? straight in no water? if it works ill try that cos i keep meaning to get some water wetter and add the to the coolant.
i didnt have a go at the guy, i wouldn't do that to some one in a shop/ garage, cos i have worked in retail and i know how shit customers can be :-(
i was just shocked at the price for a cv joint, that i later found out, may not be the right one?
the part no i have is 871 498 099 ax the guy from gsf said its for a derv burner. it also says on the print out vw gave me "wheel shaft outer with joint and attachment parts" it sounds to me like its for the whole drive shaft and cv joint?
I'm not a parts expert so thats just what i think.
as for the water pump, i heard they were metal from vw, thats one of the reasons i went there for a price.
I never knew how rude people could be before I worked in the motor trade! LOL!!!!
Once told a guy that Porsche don't make bulb kits, if he'd had a knife he would have stabbed me! Then he put a complaint in that they didn't make one as if it would make a difference!
Just wanted to tell him to piss-of to the auto centre (Jersey's version of Halfords)
The part No has been sent to my work e-mail so will have an answer for you by this time tomorrow
As for the BMW coolant it comes in 1500ml bottles can't remember the price not bragging I’ve only ever bought it at cost will get a price tomorrow.
My Tech won't use anything else, uses it in his Fiat, back in Poland he had a Golf GT (Driver over here) said he only would use G12 if he wanted to rot his engine.
The first time he told me what he was going to do I was a bit worried but I’ve tested it now in freezing conditions and the hottest and it's worked a treat nothing like when I got the GT, but when I got it, it was a right dog until he rebuilt it.
some people are just tossers for no reason :-(
i cant believe it some times.
i work in a bar now so all the tossers are drunk as well which makes things 10 times worse.
whats g12? I'm just running a 50/50 mix of coolant in my engine and it still runs a bit hot, I've all ready done every kind of test to it e.g to make sure its not the head gasket and other things like that.
so the only thing left is the pump and if that dont work I'm stumped :?
it runs a lot lower than when i got it though but still a bit high.
thanks for seeing about the cv part no :-D
G12 is the recommended VW coolant.
When I got my GT it had a head gasket problem that someone thought the best way to fix was to stick some sealant to the bit that’s leaking and that was one of many problems! Anyway the temp would go from 0 to the top in about 10 mins.
Since I fixed the entire car the highest it has ever gone was 3/4 when sitting in heavy traffic for about 15mins.
When moving it will never go higher than half way, stays between half and quarter.
What else have you tried thermostat? Coolant temp sensor?
