spraying grill surround.
i have primered it after sanding, then sanded the primer down and primered again.
waited 24 hours.
now i have put my first coat of colour on. indigo pearl blue.
do i sand it down after first coat? or just spray second coat when dry?
and after colur do i sand before laquer?
and how much do i rub it down?
may sound thick.lol but i wanna do a good job.
cheeers
  • Views 1k
anyone??
get a few coats on, then leave it to dry and give it a light going over with some 1500 or 2000 paper before applying laquer.
sweet, thanks ever so much dude, trying to get it done for polo show, haha
I've been taught to put all the coats on, then the lacquer and let that all dry properly, then get some 1500 or 2000 sandpaper, put it in a bucket with lots of water and fairy liquid to get it nice and wet, then gently sand the paint down (this is called wet flatting). Once this is done it will look crap, but give it a really good polish ( i use a electric polisher) and a wax and it will look so smart you wont believe it!
Some people wet flat after one coat of lacquer, dont polish it and spray another coat of lacquer, then wet flat and polish and wax. This takes ages, but gives a finish that is truely unbelieveable!
Wet flatting gets rid of an orange peel look-a-like finish, and a good polish and wax brings up the paint brillantly.
Hope this helps, if its too late, then sorry!
its not to late mate,
i have finished the cour,
just waiting for it to dry over night.
so would it be best to sad the clour dwn til smooth.
then laquer over?
thanks.
with pearlescent and metallic colours you cannot wet flat the base coat! you must go straight on with the lacquer.
if you wet flat the base coat it changes colour and goes all marble effect/weird.
No! Put the lacquer on first! Dont sand the base coat, gofasterpinch is right!
