Peeling lacquer
The lacquer on my red mk3 is peeling in quite a few places. Probably due to bird crap i'm told. Anyone know of a way to repair/improve it without going down the route of re-spraying the panel, as that would mean every panel on the car, which is way too expensive!
  • Views 1.7k
I'm having the same problem on part of my Polo 6n2 =\ i would love to know how to stop this from getting worse or repairing it??
If this was happening to me and i was skint id have a go at spraying it a matt colour myself.
Unfortunately the only long term solution is to flat and respray the affected panels. Once the basecoat is exposed it will alter colour with UV light, so even if you re-lacquered the panel, it would look like a patchwork quilt.
Time to start saving for that respray unfortunately - sorry.
been help to me, Thanks (Y)
unless you plan a full respray its a case of learning to live with it really, I've got a patch on my roof and a strip underneath my back window, but as mine is silver i think its easier to ignore/hide.
Treat those areas to a bit more wax than the others, I've not it had it spread since doing that.
Edited by Cymro
Strategic adhesive chequer plates :grin:
Had a feeling it would be a case of respray! Ah well, lots of wax for now and keep an eye on it to stop and rusting. A re-spray is too expensive for a good one, and cheap ones always look crap as far as i can tell, unless any of you know better? The peeling is on every panel as car was in a field covered in bird crap when i bought it and prob been there for quite a while.
